Drag NHRA, IDRC, IHRA, NDRA
5.27sec 0-60mph with stock 03 z
Old Nov 12, 2008 | 11:37 AM
zmespeed's Avatar
zmespeed
Default 5.27sec 0-60mph with stock 03 z
well my tires were bald and the road was dirty tires were 245/45/17 bfgoodrinch kdw's and i had just filled up with gas i have a full custom sterio with tons of sound insolation that adds easy 100pounds... i got carried away with dynomating. my car performance wise has an old k'n dorp in air filter. ive got other info on the run if you want. i just cant belive it did it on a cold day
Old Nov 12, 2008 | 11:40 AM
stepuckey's Avatar
stepuckey
what method of timing was used?
Old Nov 12, 2008 | 11:45 AM
This is a drag racing forum. Time slips appreciated. Anything else is…well…academic.
Old Nov 12, 2008 | 11:52 AM
athenG's Avatar
athenG
he counted 1 Mississippi 2 Mississippi 3 Mississippi 4 Mississippi 5 Missi.. He only finished less than half of the word so that is why he got 5.27sec...... J/K. Either he used a stop watched or an accelerometer like Gtech or software base one you can install on Iphone. An accelerometer is more accurate than a stop watch.
Old Nov 12, 2008 | 11:57 AM
Nealoc187's Avatar
Nealoc187
neato...
Old Nov 12, 2008 | 12:06 PM
zmespeed's Avatar
zmespeed
sorry for the lack of documentation. it as a g timer i know they arnt perfict but there pretty close. but honestly i think most of the time it reads slow. i took it to the drag strip once and it said 14.1 i the track said 14.0 but still ever if the time is 1 ten off a 5.37 is pretty good for a dusty road and 50 temp. i just got excited cause i normaly only pull 5.6 5.5 was my old record. i dont get to take it to the track as much as i would like to
i figured id take some flaming for not having it on paper but i could post pics of the g timer screen
i would have given the 1/4 mile time but i didnt have enough road to finish.
this is also the first time ive ever launched the car with out caring if i break it.
a "sterio" is: some one that thinks there funny for pointing out spelling mistakes that people carlessly make
oh and it was on a very level road... we have plenty of those in ohio
Old Nov 12, 2008 | 12:38 PM
athenG's Avatar
athenG
I have a Gtech and they are pretty accurate compare to my 1/4 time at the track. My Gtech ET was .05-.07 slower compare to my actual time ( I had 13.430 ET and Gtech got 13.50). My trap speed was also close and pretty much .3mph slower compare to my 1/4 mile Trap (Track had me 11.01mph and Gtech got 110.73). I think that is pretty good for Gtech to be less than .1 off on the ET and also less than .5mph off on the Trap Speed.
Old Nov 12, 2008 | 01:12 PM
ajcool2's Avatar
ajcool2
Originally Posted by Nealoc187
neato...
+1
Old Nov 12, 2008 | 02:11 PM
brady's Avatar
brady
Cool. I had a G-Tech last time I was at the track and it read about .1s slower then the actual time. My 0-60 time average with the G-Tech is 4.8s both ways on the road.
The G-tech is great fun.
Old Nov 12, 2008 | 02:27 PM
bacalhau16's Avatar
bacalhau16
That just arent very credible still to many real drag racers. It seems as though perhaps they have become more accurate and all, but its gonna be hard for many to believe. I will have to get one though one day and try it out.
Old Nov 12, 2008 | 02:36 PM
I guess its a pretty cool tool to play with and do comparisons. Unfortunately the numbers mean little in this forum.
Old Nov 12, 2008 | 04:01 PM
infinite's Avatar
infinite
I wish the G-TEC would work with the 07+ 350z's
Old Nov 12, 2008 | 04:26 PM
athenG's Avatar
athenG
/\ Why not? It is not car dependent... Are we talking about the same product here.. http://www.gtechpro.com/ If you are going to get one then pay more and get the RR.. Well worth it.
Old Nov 12, 2008 | 09:31 PM
scotts300's Avatar
scotts300
G-techs are relatively accurate, in our experience (within 0.05-0.1s) for times up to about 13.0s. The first-gen g-tech appears to be more accurate than the 2nd-gen when compared to actual 1/4 mile times. What you have to remember when using it against the quarter mile time slip is that the g-tech "knows" when you have gone 1320' and gives you a time and trap. The trap would be the actual speed you are going after 1320'. At the track, the final xx feet are timed and divided into distance to give your average speed over those feet. That means that the g-tech should read slightly higher in speed. Keep a log, it can help you find ideal launch and shift points - all relative at the very least.
I pulled a 2.9s 0-60 on drag radials with my first gen G-tech. Talk about a rush.
Old Nov 12, 2008 | 11:07 PM
zmespeed's Avatar
zmespeed
ya its pritty much a walky talky in a radio world... but is fun as hell to play with ever so often
Old Nov 12, 2008 | 11:23 PM
infinite's Avatar
infinite
It has the same issue the dyno tachs have with my car. it can't detect the tach signal.... I have the GTECH Pro RR i think, the one that u can put on the computer for 0-60,hp,tq, autocross, and etc. it worked well on my other car
Old Nov 12, 2008 | 11:45 PM
zmespeed's Avatar
zmespeed
you need to change the wieght settings and maybe some others
Old Nov 13, 2008 | 07:05 AM
scotts300's Avatar
scotts300
This is all the reason why the first-gen g-tech is the best.
Old Nov 13, 2008 | 07:45 AM
athenG's Avatar
athenG
You just plugged it to your cigarette lighter and you just need to calibrate it. Mine work.... I just need to calibrate it again coz my Utec logs were 100 rpm lower compare to my Gtech. You dont really need the Tach if you just want to find out your 60sec, 1/4mile..etc There is probably wrong with your Unit.
