Drag NHRA, IDRC, IHRA, NDRA
line lock for 350
Old Dec 9, 2008 | 05:34 PM
turbonetics 350's Avatar
turbonetics 350
Default line lock for 350
hello has anybody put a line lock in there car. if so what brand and did you need two or just the one. second any problems installing
Old Dec 10, 2008 | 06:54 AM
coachk's Avatar
coachk
Curious as to why you want a line lock? Its a good possibility that the guys from SP and Injected are using line locks.
Old Dec 10, 2008 | 08:23 AM
turbonetics 350
Default re line lock
want a line lock for when put drag radials on car for drag strip. little easier on the car for burnout.
Old Dec 10, 2008 | 09:04 AM
coachk's Avatar
coachk
You must have a manual tranny
Old Dec 10, 2008 | 09:40 AM
Chris@SP's Avatar
Chris@SP
Sound Performance
We don't use a line lock on our car. Not a bad investment though.
You will need 2 units as it's a 4 channel abs system. You can get the hurst roll control units, but will have to figure out the fittings necessary. We haven't gone down that road yet, but may put a line lock package together over the winter.
Chris
Old Dec 10, 2008 | 03:17 PM
Screamin350Z04's Avatar
Screamin350Z04
A line lock is a great investment. I had a hurst roll control on my LS1 car. I have no need for one on my 350 at this point but thats the route I would go. It shouldn't be that hard to do and you will never see it in the engine bay. I doubt they make necessary lines specific to a 350 but you can always make them.
Old Dec 12, 2008 | 10:04 AM
turbonetics 350
thanks for all the input needed to no if needed one unit or two. makes more sense than foot braking! easiear on car
Old Dec 15, 2008 | 05:24 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
We have done multiple line lock installs and two solenoids are required if you want to keep ABS. We have developed a kit and are waiting to test fit it before posting for sale.
Old Dec 15, 2008 | 05:39 AM
KPierson's Avatar
KPierson
I've always wanted to hijack the ABS system to do a complete electronic line lock system but I've never had the time to actually work on it.
All the ABS control wires run from the VDC/ABS controller under the dash to the ABS junk under the hood. There is a motor run signal that can be turned on (apply ground), cross over solenoids (again apply ground), and then individual wheel solenoids (ground once again). To me, it seems like if you manually turn the motor on and manually fire the cross over solenoids and the correct individual wheel solenoids you will have a line lock with $10-15 in parts. Because you want full pressure you shouldn't have to worry about any modulation or anything like that - just steady signals.
The only possible drawback I see is that it may cause the ABS system to fault out for one of several reasons:
1. The motor provides feedback to the controller when it is running. To "fix" this you would have to cut the feedback wire while the line lock is active.
2. Each solenoid is monitored. To "fix" this you would have to use relays and resistors to make the system think that solenoids are still there and not turned on.
3. There is a pressure sensor. If the system faults out because the pressure is too high when the pump "should" be off then you would have to hijack the pressure sensor voltage and make the system think the pressure never changed. This would be the hardest issue to overcome. It would be interesting to know if the pressure sensor monitors normal brake pressure or just ABS brake pressure. If it monitors normal brake pressure then it won't be an issue at all, as the system will just think your foot is on the brake.
This is on my list of "fun winter projects to mess with". It would definately be nice to have, especially if it can be done cheap.
Old Dec 18, 2008 | 10:01 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Bump.
Old Jan 27, 2009 | 08:04 PM
Peak350's Avatar
Peak350
Bump?
Old Jan 28, 2009 | 04:19 PM
Quamen's Avatar
Quamen
I have two line locks sitting in the garage but I havn't installed them yet. Bump for interest in hijacking the stock ABS as a line lock.
Old Jan 29, 2009 | 06:01 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Any update?
Old Jan 29, 2009 | 07:02 AM
Zridder19's Avatar
Zridder19
Id be interested in this too..
Old Feb 13, 2009 | 10:52 AM
Blwn_By_Twins's Avatar
Blwn_By_Twins
Me 3
Old Feb 13, 2009 | 12:06 PM
Dynosty's Avatar
Dynosty
I've got all of the pieces here, now I just need the time to finalize the setup :x I guess it's time to get it together with the racing season coming soon.
Old Feb 13, 2009 | 12:14 PM
Peak350's Avatar
Peak350
Any idea what you're going to charge for a put-together setup. I'm tempted to buy a pair of solenoids and just build my own.
Old Feb 15, 2009 | 03:07 PM
Quamen's Avatar
Quamen
I took the time today to find my line lock solinoids. I think I am going to order the fittings and line that I need so I can get them installed on my car soon. I will make a thread once I get around to doing it.
Old Feb 15, 2009 | 05:21 PM
Z ELIMINATOR's Avatar
Z ELIMINATOR
I have had line lock on my 2003 for 2 years now, I have 2 hurst soliniods and i used the red switch that was supplied in the kit. I mounted them inside the brake conpartment under the drivers side of the hood. The problem is the fittings from abs system to the solinods. I went to a hydrolic shop and had 4 custom made hoses made with the proper fittings on each end. I had them colour coded ( red and blue) Cost 250.00 for the hoses and 225.00 for the hurst kits. Instaltion time about 3 hours. It looks really good. I would post pictures but i do not know how to do it. The burnout's are great.
5 AT running 9 lbs of boost on a stillen SC.
Old Feb 15, 2009 | 05:45 PM
Quamen's Avatar
Quamen
Can anyone confirm that the fittings to the top of the distribution block are 10mm x 1.0 inverted flares????
