Drag NHRA, IDRC, IHRA, NDRA
My first run, ever. Don't laugh.
Old Sep 17, 2009 | 02:31 PM
  #41
tylerxfire's Avatar
tylerxfire
Originally Posted by djamps
U need to get a db9 connector at radio shack and connect the blue and black wires to the correct pins on the db9. Then hook it to the laptop serial port or usb to serial converter. I got the utec and aem running through a 4-port serial to usb converter so theres only one usb cable to hook to the laptop to get both utec and wideband logs.
sweet thanks man...
Old Sep 17, 2009 | 07:12 PM
  #42
Nexx's Avatar
Nexx
Originally Posted by tylerxfire
were u low 12's across the board all the way to redline?
right now im just on the 3.12 pulley but with my new tune which feels great and broke into 11's last night.If i do a say 4th gear pull from low rpm's i see low 12's like 12.0-12.1-12.2 max until i build some boost up then fall to high 11's and around 11.4-11.5 at redline..seems good i just want it to hold up, i gotta figure out how to hook up my aem wideband and log to my laptop or how i actually wire it to the laptop because it has a blue datalogging wire coming out of it i just have taped off, ill have to call aem or someone chime in..
yeah, he tuned it for low 12's at peak.
Old Sep 17, 2009 | 08:35 PM
  #43
tylerxfire's Avatar
tylerxfire
oh damn , yeah id never go near that and feel safe
Old Oct 6, 2009 | 10:41 AM
  #44
djamps's Avatar
djamps
Got a 13.1@112 last week on my ever balding OEM tires. 3 tenths better than my previous best. Don't think I'm going to be able to do much better without some supporting rubber. Looking forward to 12's soon!
Old Oct 6, 2009 | 11:51 AM
  #45
Alberto's Avatar
Alberto
Cranky FI Owner
dj where in MD do you live?
I may be willing to provide my slicks to you and some track guidance, so long as you know the possible consequances of what could happen.
Id guarantee 12.7 easy after a few passes.
Old Oct 6, 2009 | 11:55 AM
  #46
brady's Avatar
brady
I am afraid of wheel hop and breaking something to be honest. I plan on getting stiffer sub frame bushings, and maybe solid/poly diff and engine mounts.
You're dragging it at the track right? Then you're not too afraid. As others have said, work on the 60' time and work on your shifts too. Just my 2 cents.
Old Oct 6, 2009 | 12:14 PM
  #47
djamps's Avatar
djamps
I live near Crofton, a 10 minute drive from Capitol raceway. I'm assuming you mean that with slicks I might pop an axle or something similar?
Old Oct 6, 2009 | 12:20 PM
  #48
djamps's Avatar
djamps
My 13.1 run had a 2.1 60'. The rest of my 60' was between 2.2 and 2.5. My shifting is pretty consistent, I don't think that is my main problem.
the line between traction and wheelspin seems about as thick as a nut hair when launching. To compound the issue, my comp stg4 clutch is VERY grabby, and the engagement point is not always consistent.
About 50% of the time I spin/hop off the line and abort the run. Sometimes I spin half way through 1st or 2nd. I turned off the boost controller so boost doesn't come on as suddenly and it helped but my trap speeds went down a few mph.
Old Oct 6, 2009 | 12:33 PM
  #49
03threefiftyz's Avatar
03threefiftyz
Be a man.........run alberto's slicks .
Old Oct 6, 2009 | 12:42 PM
  #50
djamps's Avatar
djamps
^^ dude I would, trust me. Awaiting a PM from the almighty. LOL
350Z_Al
Oct 29, 2020 07:44 PM
Stevo Z
Oct 3, 2015 09:14 PM
Depravity
Oct 1, 2015 04:49 PM
35reilly
Sep 28, 2015 07:42 AM
