Drag NHRA, IDRC, IHRA, NDRA
Goals for 2010
Old Dec 20, 2009 | 10:40 AM
*Boose*'s Avatar
*Boose*
Default Goals for 2010
Well my goal for 09 was to hit 13's stock. I accomplished this and now would love to see 12's with gears, bolt ons, and tune and an 11 on 125 shot. Slow, but it's an achievable goal for me.
Old Dec 20, 2009 | 11:12 AM
C5_vette's Avatar
C5_vette
12's is going to be a lot harder than you think with bolt ons/tune.. very few have done it... a number of members have gotten very very close, and they are all great drivers..but its def. a hard goal to achieve. good luck...
Old Dec 20, 2009 | 11:16 AM
03threefiftyz's Avatar
03threefiftyz
12's was my goal for this year.......got REAL close. I'd like 12.80's in the spring.
Old Dec 20, 2009 | 11:23 AM
Blackbird CPV35's Avatar
Blackbird CPV35
9's
Old Dec 20, 2009 | 12:08 PM
ImWeeZzel's Avatar
ImWeeZzel
my goals for 2010 is to reach 400hp. i think adding 5/16 motordyne plenum spacer should do the trick. hopefully i can sell my rims and get some 19 axis s5f and a cw lip kit so i can call this project good.
Old Dec 20, 2009 | 01:57 PM
graffkid732's Avatar
graffkid732
Nice good luck. I have a few goals for 2010. Hopefully I can achieve them.
Old Dec 20, 2009 | 02:07 PM
ajcool2's Avatar
ajcool2
12's
Old Dec 20, 2009 | 03:46 PM
*Boose*'s Avatar
*Boose*
Yea, hoping for some perfect DA's and swapping to a better tire should do the trick.
Old Dec 20, 2009 | 04:19 PM
03threefiftyz
With an 03-06....you are going to need a DR or slick to get there on a stock long block. Trust me. It won't happen on street tires. If the temps are actually cold enough make 12 second power.....you won't get any traction.
Old Dec 20, 2009 | 04:32 PM
04fairlazdyz's Avatar
04fairlazdyz
LOW N SLO
bolt on's include f/i, correct me if im wrong, and if you cant hit 12's with f/i, you my friend are doing it wrong.
Old Dec 20, 2009 | 04:44 PM
03threefiftyz
....F/I is NOT typically associated with the term "bolt-on".
Old Dec 20, 2009 | 05:26 PM
Never did see your time: https://my350z.com/forum/drag/233840...ons-stock.html
Old Dec 20, 2009 | 05:27 PM
03threefiftyz
Me or OP?
Old Dec 20, 2009 | 05:45 PM
MardiGrasMax's Avatar
MardiGrasMax
To actually have the time to get to the stip for a few passes
Old Dec 20, 2009 | 05:48 PM
Me or OP?
*Boose*
Old Dec 20, 2009 | 10:22 PM
*Boose*'s Avatar
*Boose*
I just changed my name but my times are somewhere in that thread. But I ran a 13.948 with 2.1 60' and hoping to make that a 13.5 with some ET streets and a 1.9 60' with some good DA's and track prep should definitely be possible.
Old Dec 20, 2009 | 10:45 PM
03threefiftyz
What was your mph?
Old Dec 21, 2009 | 10:15 AM
*Boose*'s Avatar
*Boose*
What was your mph?
It was 100. The run was with a pop charger but no heat shield. Going back to the stock intake and prostars with ET streets. My tires are worn and clutch doesn't like slipping so I was limited on my 60'. Should be good for 13.50's on et streets with 1.90.
Old Dec 21, 2009 | 11:20 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Blackbird CPV35
9's
Try 10's first
My goal is to get my car to the damn track and staying straight WOT. Will need re-alignment, skinnies up front. The whole cage thing is the $$$ dealbreaker.
The times will come, I just miss running my car...
Old Dec 21, 2009 | 11:44 AM
03threefiftyz
Originally Posted by Alberto
Try 10's first
So, I guess you decided to stick with the Z.....is it at PFS? They are about a 1/2 mile down the road from me. I still haven't swung by to check out the facility.
