Drag NHRA, IDRC, IHRA, NDRA
Z Car Garage Drag Racing Series 2010
Old Oct 19, 2010 | 01:04 PM
  #41
scotts300's Avatar
scotts300
Originally Posted by fowlman01
I have DR's on this time. On 17's instead of my big azz 19's. They are a couple inches shorter when I look at them side by side. Maybe I can pull off a personal best. See you then.
Sweet, and looking forward to it.
What size are the 17" DRs? Your 275/30/19s are 25.5" tall.
I was going to take the 300, but Rob found a busted wheel bearing today, so I'll be in something else that is black.
Old Oct 19, 2010 | 01:16 PM
  #42
fowlman01's Avatar
fowlman01
the DR's on the 17's are 24" tall. (275/17) can't remember the middle #, but I measured them. I'll be in first gear for about a second. They look like donuts on the car.
Old Oct 19, 2010 | 01:28 PM
  #43
- bigc -'s Avatar
- bigc -
i won't be in town for this one. dangit
Old Oct 19, 2010 | 02:13 PM
  #44
fowlman01's Avatar
fowlman01
That's too bad! ! I'm going to try to move up a couple notches in the S/C category.
If I can't do it with DR's I guess I suck at this.
Old Oct 19, 2010 | 02:49 PM
  #45
scotts300's Avatar
scotts300
Likely a 275/40/17. If you end up running them at a decent pressure, I expect your gearing to be the same.
Dang is right!
I'm guessing you get a high 1.7s 60', which should put you about 0.2s faster, so the top 10 is in sight if you get a good run. Plus temps will be cool. With traction, that will be easy.
Old Oct 19, 2010 | 03:06 PM
  #46
fowlman01's Avatar
fowlman01
Dang is right!
I can't drive the car over 5mph with them on unless I turn off the traction control, so I guess the car thinks they are shorter too. I will start at 18#. I hope they are shorter, I can use all the help I can get. I have a couple 1.8's with the 19" street tires. I think my top time on here has a 60' that is close to high 1.8. I'm just going for the chicks.............
Old Oct 19, 2010 | 03:23 PM
  #47
scotts300's Avatar
scotts300
Old Oct 21, 2010 | 06:39 AM
  #48
scotts300's Avatar
scotts300
Great time last night, guys.
Walt - was your 12.9x run your best (not including the run at Sac with the lost sheet)?
Rob ran a screaming 11.452@119.5mph in the GreddyTT 350Z. I managed a 14.4 in the wife's basically-stock roadster.
Old Oct 21, 2010 | 06:53 AM
  #49
fowlman01's Avatar
fowlman01
This is on street tires:15. fowlman01 --------------03 350z Auto --- Vortech 12.933@104.28mph 1.914 60ft Verified Street
Last night was: 1.942 60" and 12.914/104.62 using DR's.
I'm leaving the old time up since it was with 19" street tires and has a better 60" time. I just need to dial in these tires and I think I can go up a few places.
Old Oct 21, 2010 | 07:39 AM
  #50
scotts300's Avatar
scotts300
Cool.
Now where's the pic with the hottie lady friend.
Old Oct 21, 2010 | 08:14 AM
  #51
fowlman01's Avatar
fowlman01
Cool.
Rob has a pic.
Old Oct 21, 2010 | 12:53 PM
  #52
coachk's Avatar
coachk
Walt...are you manually shifting or in full auto?
Old Oct 21, 2010 | 01:39 PM
  #53
fowlman01's Avatar
fowlman01
I shift manually....I have fast hands.
It shifts way too slow in D even though I have a shift kit. Manually I am chirping tires all the way through 4th.
I think Rob had that fast time in auto mode last night, but I bet he could knock at least a tenth off that in manual mode.
Old Oct 22, 2010 | 12:51 PM
  #54
coachk's Avatar
coachk
What gear were you in at the end?
Old Oct 23, 2010 | 07:37 PM
  #55
SE5spd's Avatar
SE5spd
stock motor? what kind of power?
Old Oct 24, 2010 | 04:43 PM
  #56
fowlman01's Avatar
fowlman01
4th.
When I use the 19" street wheels and tires I shift into fourth right before the finish line. With 17" DR's on I am pretty well into fourth. I'll check it out Weds and let you know about how long. I was shifting pretty early in first gear because I thought it would hit the rev limiter quicker. I had very little improvement over the street tires, but I think that is me. I'll try to dial in the launch and first shift.
Old Oct 25, 2010 | 09:44 AM
  #57
scotts300's Avatar
scotts300
4th.
It's an auto - what more is there to dial in? Don't you just push the gas and go?
Good luck on Wednesday!
Old Oct 25, 2010 | 10:21 AM
  #58
fowlman01's Avatar
fowlman01
Not exactly...even you should know that
Old Feb 14, 2011 | 03:04 PM
  #59
scotts300's Avatar
scotts300
Ok everyone. A day late and dollar short, but if you still have your smiley-faced time slips, we are going to tally them up, close out last year's event, and get ready for this year's event.
Old Feb 14, 2011 | 09:08 PM
  #60
fowlman01's Avatar
fowlman01
I will try to find mine.
etkms
Jun 19, 2022 06:30 PM
SpartanZ32
Oct 22, 2015 09:36 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
Mw870
Sep 10, 2015 07:50 PM
