Drag NHRA, IDRC, IHRA, NDRA
5at TT best
Old Apr 15, 2011 | 08:56 AM
k6750gsxr's Avatar
k6750gsxr
Default 5at TT best
PERSONAL BEST... only two runs...12.3 and this one.
04 TOURING 5AT
GTM TT 30R'S
NT05R RADIALS
9 PSI RUN.
11.94
http://www.youtube.com/watch?v=Y4M9eWQmXFc
Old Apr 15, 2011 | 09:02 AM
Nexx's Avatar
Nexx
good schit, work on that 60 ft and low 11's isnt far off
Old Apr 15, 2011 | 09:26 AM
eltness350's Avatar
eltness350
The Untouchable
^^+1 nice job!
Old Apr 15, 2011 | 09:30 AM
ehsan's Avatar
ehsan
Kinda makes me wish i went with you last night..
Old Apr 15, 2011 | 09:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
How much power?
11's is very respectable in only a few runs.
Old Apr 15, 2011 | 10:06 AM
k6750gsxr's Avatar
k6750gsxr
9.4 what the peak boost on logger. Some where in the 450 area I would imagine going by the mph. That was my 5th pull with this set up. Only made 2 pulls last night because the track guy told me I needed a helmet.
Thanks for all the positive feedback guys. This has been a long journey. I have been screwed by a shop a lot and did this my self. So I am content.
For the life of me I can't get it to launch harder. That's why my 60ft was on the high side.
Old Apr 15, 2011 | 10:10 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Sometimes, going "easier" off the line will result in faster 60ft's.
Is your tire pressure down to 16-18psi? Are you properly heating them up? Radials shouldnt be run higher at the track.
With a 1.7 thats an easy 11.70 pass....
Old Apr 15, 2011 | 11:20 AM
k6750gsxr's Avatar
k6750gsxr
Tires were 18 psi... hooked very well. Heat cycle them every time. I launch with the stall up to pre load the trans. Never cones out the hole hard because the highest I can pre load it is to 2900rpm before it starts to creep forward.. Not enough for the turbo to spin up.
Old Apr 15, 2011 | 11:45 AM
rcdash's Avatar
rcdash
Nice run! Do you have pin 101 of the ECU disabled so you can do a brake torque launch effectively without the ECU closing the throttle? I can get to maybe 1 psi with a spark cut brake torque launch at 2500 rpms (twin GT28s). I can on the fly reroute the brake signal (pin 101) to the aux rev limiter of the Haltech to give me a 2 step.
Old Apr 15, 2011 | 11:51 AM
ajcool2's Avatar
ajcool2
At first I thought your RT was your 60' haha. Nice job reppin the 5at's. Everybody breaking 11's but me.
Old Apr 15, 2011 | 12:56 PM
k6750gsxr's Avatar
k6750gsxr
I pulled the break fuse. Figured that's all I needed to do. Isn't the 101 pun the same thing its just easier if you want to do it on the fly ?
Old Apr 15, 2011 | 01:03 PM
k6750gsxr's Avatar
k6750gsxr
Actually on the 11.9 run I didn't have the fuse removed. I was still able to do a good heat up on the tires. I thought with it not removed you couldn't do a burn out.
Plus I have osiris on my ecu which allows me to keep it open ?
Rcdash what is your best run ?
Old Apr 15, 2011 | 01:13 PM
ajcool2's Avatar
ajcool2
Not quite. Ive had times where I my rpm would rise real slow with my brake fuse pulled and I would let off the brake pedal just a little and the rpms would jump up. So it still cuts power a little.
Old Apr 15, 2011 | 01:18 PM
ajcool2's Avatar
ajcool2
I would assume you are making enough power to spin the tires even with the fuse in. I can do weak burnouts with my fuse in.
Old Apr 15, 2011 | 02:47 PM
NissanZ03's Avatar
NissanZ03
Good stuff man
Old Apr 15, 2011 | 04:01 PM
ImWeeZzel's Avatar
ImWeeZzel
could you post pics of your car please? Id like to see this bad boy.
k thanx
Old Apr 15, 2011 | 04:07 PM
ehsan's Avatar
ehsan
here:
Old Apr 15, 2011 | 04:12 PM
kacz07's Avatar
kacz07
^Oh wow, oh...
Old Apr 15, 2011 | 04:24 PM
ehsan's Avatar
ehsan
A buddy of ours owns a vinyl business so we help promote his work. New and different design coming soon for his car
Old Apr 15, 2011 | 04:26 PM
k6750gsxr's Avatar
k6750gsxr
here are some pics .....
