Drag NHRA, IDRC, IHRA, NDRA
My drag set up
Old Oct 14, 2011 | 01:44 PM
neverenough's Avatar
neverenough
Default My drag set up
These are some old pics from IFO earlier this year. We ended up winning the True Street class with a best pass in the final round 10.6@140mph. This was only the seventh pass on the car so I was still taking it easy. Wheels are Weld Aluma Stars 17x4 front and Jegs pro stars 15x8 rear. I'm bored and missing my car so I decided to post a few pics.
Old Oct 14, 2011 | 03:32 PM
tookrzy4u192's Avatar
tookrzy4u192
Looks aggressive. Care to share the mod list?
Old Oct 14, 2011 | 03:38 PM
350zion's Avatar
350zion
Professional
Looks so sweet, wish I could fit those over my Brembos....
Old Oct 14, 2011 | 03:39 PM
350zion's Avatar
350zion
Professional
Btw specs on tires? If u don't mind...
Thanks
Old Oct 14, 2011 | 04:32 PM
neverenough
Thanks
front M&H Racemaster 26x4.4x17
rear MT ET Street 28x11.5x15
Old Oct 14, 2011 | 04:33 PM
neverenough
These wheels clear the bigger 06-08 front brakes without spacers not sure about Brembos.
Old Oct 14, 2011 | 04:39 PM
neverenough
GTM Built 3.8l HR
GTM Twin GT3076
GTM Complete fuel system w/twin pumps and billet rails
OS Giken twin disk
DSS Pro axles
HKS F-Con w/Knock amp and Navigator
GTM exhaust
724whp 714wtq @20psi
Nismo suspension
quaife lsd
Old Oct 15, 2011 | 01:10 PM
350zion's Avatar
350zion
Professional
Definitely done right! Congrats on the numbers as well......
Old Oct 27, 2011 | 03:32 PM
ffwturboZ's Avatar
ffwturboZ
That is one sweet set up!!! The 17's look like the would clear brembos, I would love to get my hands on a set for the front of mine... Nice work!!
Old Oct 27, 2011 | 03:58 PM
24k's Avatar
24k
Looks awesome.
Old Dec 7, 2011 | 03:58 PM
2bad240's Avatar
2bad240
you ever ran 26s on the rear? i have a set of 26" m&h racemasters on the rear of mine now and im just not happy with them. i cant get my 60' down below a 1.61 i have experimented with the psi alot and i just cant get rid of that wheel spin.
Old Dec 7, 2011 | 06:28 PM
neverenough
I ran 26s when I had the stock block and the stage 1 twin turbos. I needed to move up to the 28s with a 140mph trap speed I am trying to stay in 4th. Last pass I went through the lights on the rev limiter in 4th so I may end up trying a 3.3 rear gear in the future.
Old Dec 8, 2011 | 01:29 AM
2bad240's Avatar
2bad240
i may try some 28s then, im going through on rev limiter in 4th now on the 26s.
and i just cant get my 60' down anymore.
im just worried i dont have enough power for the the 28s, right at 390hp/410tq
Old Dec 8, 2011 | 07:11 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
LOL @ you complaining about 1.6 short times. Most of us wish we can cut below 1.7s.
Also, power has nothing to do with tire height. All you're doing is changing the gear ratio by a very small increment, which allows you to stay in gear longer or shorter.
With 26s, you should be hitting the rev limiter at like 109mph or something (stock tire height tops out at 111mph in 4th). 28s will probably give you slightly higher short times but you'll definitely be in 4th gear, assuming you don't trap over something like 113mph.
Old Dec 8, 2011 | 09:36 AM
str8dum1's Avatar
str8dum1
i dunno, read the drag forums at supra forums. Those guys have strict power guidelines they follow when up-sizing their tires from 26 to 28"
ya 1.6 on a standard is not bad esp on this platform.
Old Dec 8, 2011 | 02:21 PM
djamps's Avatar
djamps
I trap 119mph 4th@7000 with my 26" ET Streets. stock rear.
I recommend giving the ET streets a spin. I have had ZERO wheelspin with proper warmup, my best is 1.7 60ft. I need practice, not tire.
Old Dec 8, 2011 | 02:26 PM
ffwturboZ's Avatar
ffwturboZ
Wish I could hit 1.6's.. I hit 1.77 with the 26" tires. Now with the 28" Im catching hell getting below 1.9, but have higher trap speed. May go back to the 26"...
Old Dec 8, 2011 | 02:39 PM
3hree5ive0ero
Retired Admin
I best is a 1.7, also, on ET Streets.
Well, of course, taller tires mean more mass/weight therefore more power needed to justify using them. More power also means higher trap, which means that if you're having to shift or hitting the rev limiter, taller gears/tires would help. However, in no way is more power a requirement.
Old Dec 8, 2011 | 03:11 PM
neverenough
If anyone is concerned about weight the MT Radials were way heavier then the MT Bias plys I am on now. The bias plys are the way to go on a 6 speed car IMO.
Old Dec 8, 2011 | 03:22 PM
350zion's Avatar
350zion
Professional
HA if this was my only complaint...
Was tryin to get lower than a 2.0 60' on mt drag radial the whole season... Broke axles were my latest endeavor...
Switching tires and turning up the boost next season....
