Drag NHRA, IDRC, IHRA, NDRA
Went to Track with Last Nigt w/ Test Pipes
Old Dec 20, 2003 | 04:34 AM
350_Z's Avatar
350_Z
Default Went to Track with Last Nigt w/ Test Pipes
I went to the track last night, my only added mod was the LSD Test pipes. I only dropped a .10 off my best time but neither run was great both had a 2.3 and 2.4 60 ft time. But what was impressive was the MPH change. I gained almost 2mph over my previous runs when I only had an intake. My previous best MPH was 99.8. Here are my results from last night.
R/T 1.126
60" 2.321
330 6.181
1/8 9.254
MPH 80.65
1000 11.895
1/4 14.113
MPH 101.74
Old Dec 20, 2003 | 02:39 PM
orhanz33's Avatar
orhanz33
is your car an auto?
Old Dec 21, 2003 | 09:37 AM
themyst's Avatar
themyst
wow, great run. get that 60ft down to 2.0 - 2.1 (pretty easy to do on stock tires) and you'll be in the high 13's easily. keep practicing, and remember on the Z... no wheel hop = good. Do NOT break traction, slip the clutch with just enough gas to move you forward but at the same time not break the rear loose. The split second you feel the tires grip, mash the gas. you will bog if you don't. But you will have a slightly lower trap time going by this method... faster ET though.
Old Dec 21, 2003 | 09:44 AM
jackie chan's Avatar
jackie chan
are you running at speedworld? if so pm me next time you go out to the track and i will give you some help launching out there. i'd like to finally see a z run mid 13's without the spray out there, and i think your car could with that mph. once you get the hang of launching it you should be 1.9s-2.0s depending on your tranny (auto/manual)
Old Dec 22, 2003 | 03:43 AM
350_Z's Avatar
350_Z
Yeah I was out at Speedworld. I'll definitely pm you next time I go, I think the track is closed until the 2nd week in January so hopefully it will be around then. Oh and my car is a Manual.
Old Dec 22, 2003 | 04:29 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Let me know too, I'll go out there with you guys.
Old Dec 22, 2003 | 05:29 AM
350_Z's Avatar
350_Z
Ok, I'll be sure to do that...
I've never even seen any other 350's out there racing, so I don't have anything to compare my car to. Some of the guys at the track said the fastest 350 they have seen to date ran a 14.2 and most were mid 14. Everyone said my trap was good.
Old Dec 22, 2003 | 01:13 PM
jackie chan
i drove a touring z that we have at the dealership and i think it should be pretty easy to cut a 2.0 60' in it...with a 60' lik that you should go 13.6-8 with your mph
Old Dec 24, 2003 | 11:17 AM
redls1's Avatar
redls1
I live in clermont but give me a shout also. I havent been to the track in a long time but would like to go again. Do any of you know of a place to do some installs? I bought the borla headers and am going to buy UOR pulley.
Old Dec 25, 2003 | 08:56 AM
PhantomZ's Avatar
PhantomZ
i'll go, somebody lket me know... maybe I can kill more of my crappy dodge tranny...and get a new, built tranny.
Old Dec 25, 2003 | 07:06 PM
BlackNissan350z's Avatar
BlackNissan350z
Ill go with you guys as well, let me know
Old Dec 25, 2003 | 07:43 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Track opens back up Jan. 15 so lets pick a Wed./Fri we can all meet up after Jan. 15
Old Dec 26, 2003 | 12:24 PM
BlackNissan350z
i prefer wedesdays, but that might be a pain for most others, its alot slower on wednesdays there
Old Dec 26, 2003 | 01:10 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
that's when I usually go as well.
Old Dec 26, 2003 | 03:49 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
You're right...I didn't have any problem cutting 2.0x 60' times on the stock RE040s my first time at the track with the car.
Old Dec 26, 2003 | 04:00 PM
jackie chan
i'm off on wednesdays, so that is the day i usually go
Old Dec 26, 2003 | 09:58 PM
BlackNissan350z
so wednesday seems like a good day, just let me know what wednesday ive got a srt4 to pick on us all....ill need some help from someone there as my last time at the track was a disaster, 15.2 with tractions control, then 1st gear pop end yeiled a 15.4, then a 3-2 shift nearly blew up my car and i rolled thru at 14.7@74 it wass bad day
Old Dec 27, 2003 | 10:57 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
How's the 28th for everyone?
Old Dec 27, 2003 | 11:16 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
started new thread https://my350z.com/forum/showthread....threadid=54735
Old Dec 27, 2003 | 01:28 PM
jackie chan
i posted in the other thread, but if you are a track newbie, dont expect to run very quick. but if you find someone that knows what they are doing to help you out your times will improve much quicker than trying to figure it out on your own
