Drag NHRA, IDRC, IHRA, NDRA
13.80 HR my 2nd time in the track!
Old Nov 12, 2012 | 10:27 AM
jdmlove1's Avatar
jdmlove1
Default 13.80 HR my 2nd time in the track! updated** 3rd time 13.74
hiii!! i just came from the drag, we had an open drag day at Bahrain!
its like 28 degrees
my 1st run was 16 something because i launched the car with 2.5k rpm!! too much slip!!
my 2nd run 14.2 lunched the car with below 2k rpm!!
3rd run i removed my spare tire! launched the car with 1.5K Rpm!! little bit spin but better than the above runs!! i got 13.80 i was soooo happy!!
my car almost stock!! only CNT resonated test pipes and k&n drop ins and i removed the middle resonator from the exhaust.! my tires where 295 toyo proxxes with ce28 wheels
my 4th run!! reduced the tire pressure to 35 PSI!! had a great launch!! even my friend told me it was my best launch!! when i shifted second the clutch slipped!!!! so i had to remove my foot little bit !! then pushed it again and brought 14.08
the the 5th and 6th run!! all the same clutch problem when i shift to 2nd gear!!
my friend told because u had too much grip in your tires so your stock clutch couldn't handle it!!!
i was happy!! but i need clutch advise!! i think with a decent clutch i should reach 13.5!!
Old Nov 12, 2012 | 10:34 AM
Bmurray350z's Avatar
Bmurray350z
post a time slip...
Old Nov 12, 2012 | 10:35 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Congrats on progression
Old Nov 12, 2012 | 10:41 AM
jdmlove1's Avatar
jdmlove1
post a time slip...
i lost the slips, i will make sure to post them next time!
Old Nov 12, 2012 | 10:42 AM
jdmlove1's Avatar
jdmlove1
thanx, i really got excited! the next open track day will be 26 nov! hopefully get better times
Old Nov 12, 2012 | 10:51 AM
KingBaby's Avatar
KingBaby
Hardest Setting
So you launched at 1.5 and got the best time. What tires are you on?
Old Nov 12, 2012 | 10:54 AM
jdmlove1's Avatar
jdmlove1
Toyo Proxes, 295-30-19
Old Nov 12, 2012 | 04:29 PM
djamps's Avatar
djamps
HR can do low 13 / high 12 with practice. Keep trying!
Old Nov 12, 2012 | 05:07 PM
Bmurray350z
do you remember what your 60' was like?
Old Nov 12, 2012 | 05:11 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Good question
Old Nov 12, 2012 | 08:16 PM
jdmlove1's Avatar
jdmlove1
no!! i really didnt care about the time slip or reading it, my friend was bringing them after each run and i see them and through them away!!
i know that my reaction time was not good!! because always wait for the next to launch and then i lunch after it
Old Nov 12, 2012 | 08:17 PM
jdmlove1's Avatar
jdmlove1
which clutch i should with for the drag?
Old Nov 12, 2012 | 08:24 PM
SR71's Avatar
SR71
Lead Super Moderator
What do you normally have you tires set at?
Old Nov 12, 2012 | 09:36 PM
jdmlove1's Avatar
jdmlove1
they was 38 PSI!
Old Nov 24, 2012 | 02:55 PM
xslangx's Avatar
xslangx
omg this guy screams Honda Civic all over the place..
how the fck are you launching at 1.5k -_-
Old Dec 3, 2012 | 04:11 PM
jdmlove1's Avatar
jdmlove1
this time i made sure to take my time slips
i have 4 runs , my best was 13.74 .. i felt i could do better... but i cant just find the perfect launch!! i will post videos 2moro
my car number 3
video
from inside the car
http://m.youtube.com/watch?feature=plcp&v=zzj4eZUArzI
Old Dec 3, 2012 | 04:20 PM
Italianjoe1's Avatar
Italianjoe1
Yeah with less trap speed and a better launch I ran 13.50s, you gotta get the car moving quicker. Practice!
Old Dec 3, 2012 | 08:34 PM
jdmlove1's Avatar
jdmlove1
where is showing my trap speed in the slip??? do u mean the 60" time??
Old Dec 3, 2012 | 10:51 PM
Italianjoe1
Very bottom line, 169.9 km/h. About 106mph. I was trapping under 104 and running 13.50's with a nothing special 2.05 60' time. Your car is making good power and will run low 13's with a decent launch.
Old Dec 3, 2012 | 11:45 PM
jdmlove1's Avatar
jdmlove1
thanks for explaining started to understand now
i think my open LSD dont help.
