Drag NHRA, IDRC, IHRA, NDRA
Fustrating night at the drags...
Old Apr 25, 2004 | 12:23 PM
Daytona Blue Z in Bo's Avatar
Originally posted by slowmo12
you car will not make any adjustments to fuel settings due to an added octane. the added performance of higher octane comes from the ability to run a leaner mixture without detonation. so if you are running stock a/f ratios you will not see any gain from a higher octane. some ECU's will adjust timing when it does not sense detonation, as a benefit to give more power. adding octane is not going to cause detonation at all. if your ECU has variable ignition timing, and it senses detonation, then it will retard the timing causing a loss in power. using octane some kinds of octane boosters will cause your 02 sensors to think the catalytic converters are not functioning correctly. this will result in a malfuction CEI, which should not affect performance at all. basically, there is no way octane booster is going to decrease your performance, even on an N/A car. Your decreased time at the track could have been due to several different reasons (barometric pressure ect).
Thanks for the info!
Now if only my plenum would be delivered
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
wayneside
North West
Sep 23, 2015 02:23 AM
