Drag NHRA, IDRC, IHRA, NDRA
cause of wheel hop????
Old Sep 8, 2004 | 05:59 AM
redline350ZZ's Avatar
redline350ZZ
Default cause of wheel hop????
What is the cause of wheel hop on the Z and can better tires correct this problem?????? what would break or be damaged from wheel hop???
Old Sep 8, 2004 | 11:37 AM
dwnshift's Avatar
dwnshift
Try our trailing arms and rear spherical bearings. They will let the rear hook up a lot more.
Old Sep 9, 2004 | 11:54 AM
g35irish's Avatar
g35irish
Wheel hop can be caused by several different things, but adding traction is directionally correct. The source of the problem, however, is usually the shocks, and specifically that the rebound is too soft. As the car moves forward, torque is created as the tires create traction to start this movement. Excessive separation (axle centerline to body) can lead to wheel hop. Stiffening the rebound can control wheel hop if excessive separation has occurred.
As far as parts breakage: the short answer is YES. It can (and will) break axles, shocks, motor mounts, etc.
Old Sep 9, 2004 | 12:56 PM
redline350ZZ
So buy better shocks....Engine mount damper???? What about Kinetix traction bars????
Old Sep 9, 2004 | 01:56 PM
dwnshift's Avatar
dwnshift
Ask Bluefish with the NHRA drag 350Z how our parts are working on their car.
They recently installed our rear arms and rear spherical bearing kit.
The key is to take the suspension bind out and allow for better/ smoother movement.
Old Sep 10, 2004 | 09:50 AM
redline350ZZ
how much are just the rear trailing arms????? I already have a camber kit for the rear ????? Is this the same as the Kinetix traction bars????
Old Sep 10, 2004 | 07:53 PM
orhanz33's Avatar
orhanz33
if i get these is it garaunteed i won't get wheel hop? how diffucult is the install for these items? about how much do you think the install will cost?
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
