Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Modified steering bumpstops to get more angle
Old Jan 1, 2008 | 01:40 PM
n1sm0r's Avatar
n1sm0r
Default Modified steering bumpstops to get more angle
So have any of you guys modified your bump stops?
I already have tein inner tie rods with spacers, but I want to push a little more angle out of my rack.
Anyone done it? Just curious how much you've shaven off.
Old Jan 4, 2008 | 08:33 AM
nick hogan's Avatar
nick hogan
the answer is not in the bumpstops(they come off by the way if i remember correctly)
but anywho, on my Z's ive made a few custom pieces that help dramatically when looking for more steering angle
they will be available to the public soon and i will keep everyone informed
Old Jan 10, 2008 | 09:31 PM
powermark's Avatar
powermark
just shorten up the distance from the tie rod mounting point on the spindle towards the center
Old Jan 11, 2008 | 07:16 PM
willyd6869's Avatar
willyd6869
I have battle version Tie rods, and to get full steering angle I had to cut my stops like 1/2 inch
Old Jan 15, 2008 | 09:39 PM
Topics II's Avatar
Topics II
since all tie rods are different, best thing to do is take them out, and cut your wheel all the way. measure how much distance it is from the arm to the steel stopper and cut the remainder off. then after that, if you are getting a lot of bindup from the tie rod over-centering, you can add a washer or two to the stopper in the arm to take some angle out so that your wheel doesnt get stuck at full lock.
Old Jan 17, 2008 | 04:25 PM
n1sm0r's Avatar
n1sm0r
thanks chris, yeah I got everything done a while ago, forgot to update this thread
Old Aug 16, 2008 | 12:42 PM
nismo69's Avatar
nismo69
Anyone have pics of there modified stops? I just got the spl outter tie rods and tein inner putting them in monday.
Old Aug 17, 2008 | 07:54 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
its not the bump stops, just take all those parts off.
next problem is going to be the inner tie rods hitting the end of the steering rack when its full lock. you can get smaller inner tie rods that go into the rack to get a lot more angle. also be careful of the offset of the wheels hitting the rear lower control arm up front. J- arm some people call it.
have fun and be safe!!
Old Aug 20, 2008 | 08:33 AM
TopNotch's Avatar
TopNotch
toe out might work for more angle;
if you set your alignment with a little bit, (and i mean a LITTLE BIT) of toe out, maybe .5 degrees total, you will get a little bit more angle on the front wheel thats got the most weight on it.
Explanation for those who dont know what im talking about;
if you go into a left hand turn to drift, your obviously gonna be turning the wheel to the right, so, the majority of the front weight of the car is on the FR wheel, so if you have toe out, that FR wheel will have more angle, but it will still be stable. Same goes for the opposite direction drift. Its an easy way to get some more noticable angle out of your front end.
Sorry if this was obvious, just throwing it out there...
sales@czp
Sep 23, 2019 03:30 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
