Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Tires size
Old Sep 20, 2010 | 03:48 PM
Bigalow's Avatar
Bigalow
Originally Posted by 350zRiot
I'm going to just keep the suspension stock until i can afford coilover because i want to lock up all the suspension bolts so that there's less change in alignment during drifting.
So 8.5 wide would be the general size for my rear? IMO, 9 wide would be a wise choice for long run because i can prolly put 235/50, 245, 255 and still have less wall flex. Since i'm running 45 profile for front, i have to run 50 profile rear.
8.5 is ok in the REAR but 9 or 9.5 is probably better for you. I know JasonZ-Ya loves running his 17x9.0 when he drifts so I bet he has good reason. 8.5 or 9 should be good for you up FRONT.
Old Sep 20, 2010 | 07:02 PM
JDMStanced's Avatar
JDMStanced
Now we are settled with 9 wide rims Now with tires, How's 235/50/17 in the rear with 225/45/18 in the front? When i need to change my front tires, i'll get 235 but they still have plenty left.
Old Sep 20, 2010 | 07:14 PM
skakemokid's Avatar
skakemokid
I'll pick up the 225/45/18 from you, and you go buy some 235 =)
Old Sep 20, 2010 | 07:17 PM
JDMStanced's Avatar
JDMStanced
haha. That would be niicce if i don't lose any money These are stock tires
Old Sep 20, 2010 | 07:24 PM
skakemokid's Avatar
skakemokid
i have some 235/40/18's
Old Sep 20, 2010 | 07:42 PM
JDMStanced's Avatar
JDMStanced
I need 45 because the rear would be 50/17. It wouldn't matter that much for now using 225 front because i'm a beginner
Old Sep 21, 2010 | 01:10 AM
Nackers's Avatar
Nackers
There are other ways to combat understeer.
I use 18x9 with 235/40 on the front. Sway bars and 0* toe. No understeer here.
I also use 235/40 in the rear on 9.5 and 10's. I could use a slightly larger tire for more grip now, but I used the same setup when I was N/A and it worked out well for me.
