Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Under $2000 coiloversfor drift,which would u recommend?
Old Jul 13, 2011 | 01:56 PM
Max-G's Avatar
Max-G
Originally Posted by lin56hk
max pro coilovers are true coils and comes with swift springs for $1500 (from the site), correct?
correct.
Old Jul 13, 2011 | 02:20 PM
lin56hk's Avatar
lin56hk
right now its
BC ER ~1700
vs.
Stance GR+ pro or SSD ~1200
vs.
Max pro ~1500
vs.
fortune with swift spring + helper spring ~1500
hmmm...
Old Jul 13, 2011 | 02:57 PM
RurouniMidnight's Avatar
RurouniMidnight
Didn't know the psm came with the swifts, i thought they were extra wow thats a great deal!
Old Jul 13, 2011 | 03:11 PM
Max-G's Avatar
Max-G
DEFINITELY go with max pro. the springs alone make them worth it.
Old Jul 13, 2011 | 03:31 PM
512_Z's Avatar
512_Z
I agree with MAX G, PBM are worth it for that price. I have stance looking in to buying them. A lot of 240 drift with these and their damping is amazing. Good coils.
Old Jul 13, 2011 | 05:07 PM
o.g.darkdrifter's Avatar
o.g.darkdrifter
I have friends with PSM's (the originals) and they all say they are a little on the stiff side for dailying but they handle amazing. And by stiff they mean more of just a solid feel, not bouncy or sloppy. Don't know anyone with the new pro's though. I've heard the dampening has been improved and they aren't as stiff feeling as the previous models while managing to handle better.
Old Jul 13, 2011 | 06:29 PM
lin56hk's Avatar
lin56hk
whats the deal with max pro's swift springs? fortune has them along with helper spring for 1500 too
and i believe BR ER and stance GR+ pro has helper springs too (not swift...difference?)
i found their spring rates for Z33 at 10/12 KG, the rear is stiffer than front? how does that affect the car performance in terms of drifts and street runs? i do a bit of spirited street driving taking hard corners
need moar suspension gurus
Old Jul 13, 2011 | 09:19 PM
Max-G's Avatar
Max-G
i'm pretty sure you got it backwards. 12k front, 10k rear. imo, that's the perfect spring rate for the z. i run 12/8k and bumping the rear up to 10k seems like it would be much better to me.
swift springs aren't the same as helper springs. swift is a brand. helper springs are a type of spring. swift springs are progressive springs, which will ride much better.
fortune and pbm are the same price and both have swift springs, but the fortune coilovers don't nearly have as much time put into r&d as the pbm coilovers do.
Old Jul 13, 2011 | 11:17 PM
lin56hk's Avatar
lin56hk
Z33 10/12 KG
dont people put front spring rate in the front and rear spring rate at the back
http://zilvia.net/f/advertiser-annou...p-max-usa.html
Old Jul 13, 2011 | 11:28 PM
Max-G's Avatar
Max-G
usually. i know for a fact that all those other spring rates in that thread are flipped so the spring rates for the z are 12k front, 10k rear. idk why dan wrote them backwards.
Old Jul 14, 2011 | 10:15 AM
o.g.darkdrifter
From my experience coilovers with helper springs are generally a waste of money (vs the non helper spring version). Ride isn't as smooth and the handling advantages aren't enough to justify it.
Old Jul 15, 2011 | 04:04 PM
lin56hk's Avatar
lin56hk
looks like its gona be part shop max, unless anyone has any last minute recommendation
Old Jul 15, 2011 | 04:20 PM
JM Auto Racing's Avatar
JM Auto Racing
MY350Z.COM Sponsor
The D2 would be better than the BC coilovers and alot better than stance. Their D2 Drift series coilovers are fine tuned for drifting. Not talking about the RS version but the D2 Racing. D2 even gives you a 3 year warranty and are rebuildable in the united states.
Not to mention, since the D2 Drift Specs have to be custom built, you can build them with any rate you want.
__________________
Email:sales@jmautoracing.com
AIM: jmautoracing@gmail.com
www.jmautosports.com
1-855-998-8726
Old Jul 15, 2011 | 04:22 PM
JM Auto Racing
MY350Z.COM Sponsor
WE have personally built many cars for the drift circuits as well as drag and the specialty feature coilovers that D2 offers such as their Drift, Rally, and Drag really focus on the specific type of ride that you are going for
__________________
1-855-998-8726
Old Jul 18, 2011 | 04:10 PM
JM Auto Racing
MY350Z.COM Sponsor
Here is some more info on the newly designed D2 Drift Coilovers... which are far better than pro Max in my opion:
-To enjoy the real drifting to the extreme, this is an excellent coilover which is
different than the only ride height adjustable coilover.
-All McPherson suspensions offer mono and inverted tube design (φ55mm). It can
bear the sideway aggressive movement and strong gravity when drifting.
- There are some certain rear dampers should come with helper springs to operate
the sideway aggressive, ground the rear inner tire, and against with ground when
drifting.
- All McPherson coilovers come with pillowball upper mount with camber plate. It
adjusts the camber of the tire and get the tires have better turn and enhance the
stability of the vehicles.
-The specialized rear spring rate setup can make the inside tire to press down the
road without affecting the stability of vehicle. Furthermore, it accelerates the rear
tires turn around to drifting handling for high-speed.
- There are 36 different dampening settings to meet different requirements of
race-road conditions and varieties vehicles.
-If there is no application desired, we can customize the coilover for you to meet the
requirements.
- Camber and caster can be adjusted by 3D pillowball top mount which for your
options.
- For certain custom racing strut, our company has right to determine to use inverted
insert.
__________________
1-855-998-8726
Old Jul 20, 2011 | 08:09 AM
Junkster's Avatar
Junkster
Since when could you adjust camber and caster from the pillow ball mounts on a 350z?
Copy and paste is bad pastey lol..
Old Jul 20, 2011 | 08:15 AM
o.g.darkdrifter
LOL. I was thinking the same thing.
Old Jul 20, 2011 | 11:35 AM
  #38
JM Auto Racing
MY350Z.COM Sponsor
He was stating he was going to get a camber arm kit from SPC.... not actually adjusting from the pillowball mounts
__________________
1-855-998-8726
Old Jul 20, 2011 | 11:37 AM
  #39
Junkster's Avatar
Junkster
^ I was just commenting on the D2 details that you posted, not all of it applies to a 350z (ie the camber and caster adjustment from the top mount).
Old Aug 8, 2011 | 07:39 AM
  #40
gotboost36's Avatar
gotboost36
I have fortune 500's right now and they are amazing! I dont know why people talk **** about d2's... I had them on my evo and loved them
