Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Drifting + VDC = ?
Old Oct 13, 2004 | 04:52 PM
Tizom's Avatar
Tizom
Default Drifting + VDC = ?
hey all, im a n00b, 1st post style...
question for the drifters with and w/o VDC, i was wondering how different the cars behave...i have heard (dont hold me to this) that once you dis-engage the VDC a portion, just a tiny percent is still ON....and may produce alittle understeer than a Z33 without VDC. Now i am not sure, i just wanted to make sure, and if it does ok, and if it doesnt explain why/how.
And do you drift w/ your VDC equipped Z? or do the majority of drifters on this site preffer non-vdc Z's
thanks alot!
Old Oct 13, 2004 | 07:20 PM
03Z33's Avatar
03Z33
just pull the fuse and you'll be fine
Old Nov 6, 2004 | 08:17 PM
uro279's Avatar
uro279
Where's the fuse?
Old Nov 7, 2004 | 01:21 AM
03Z33's Avatar
03Z33
Originally posted by uro279
Where's the fuse?
It's the red square 50 amp fuse in the lower right corner of the fuse box under the hood (in the same compartment as the battery)
It is the only red larger style fuse in that compartment.
When you first drive with it out the: VDC, Brake, Slip, and ABS lights will go on indicating that those three functions (including the traction control) are disabled. You should feel the difference in throttle response and brake feel immediately
Old Nov 7, 2004 | 10:21 AM
basam350z's Avatar
basam350z
Is this better at the 1/4 and drift track to pull the fuse or just shut VDC off?
Old Nov 8, 2004 | 02:40 PM
03Z33's Avatar
03Z33
I feel I get a better launch and better throttle response with the fuse pulled. This is also the only way to fully disable the brake traction control.
Old Nov 28, 2004 | 02:41 PM
OvaYahead's Avatar
OvaYahead
and leave the fuse in your glove comparment to put back in on rainy days.
The VDC not totally disengaging saved my G.
Old Dec 7, 2004 | 08:50 PM
OvaYahead's Avatar
OvaYahead
did anyone get a clicking noise in the front under hard breaking after pulling the fuse?
I had some clicking, but it went away after I just put the fuse back in today.
Old Dec 26, 2004 | 02:36 PM
DLin05's Avatar
DLin05
i pulled the fuse...and no lights came on
Old Dec 26, 2004 | 09:06 PM
03Z33's Avatar
03Z33
Which model 350Z do you have?
Old Dec 27, 2004 | 12:20 AM
DLin05's Avatar
DLin05
touring
Old Dec 27, 2004 | 11:03 PM
03Z33's Avatar
03Z33
touring
From my experience in all VDC equipped cars the Slip and VDC lights will come on once you begin driving if you remove the ABS/VDC fuse. Can you confirm that this is the fuse you removed? Did you actually drive the car with the fuse pulled?
Old Dec 29, 2004 | 12:01 AM
DLin05's Avatar
DLin05
Yea, I drove around a bit today and they came on
Old Aug 25, 2005 | 11:59 AM
bio911's Avatar
bio911
hmmm i am going to try this.. something i just found out.. lets see if it will improve the 1/4 times
Old Aug 26, 2005 | 07:18 AM
Chebosto's Avatar
Chebosto
Open hood, Open Brake Fluid cover box-
there will be a small Grey colored cable going into a Silver aluminum ABS box along the fenderwall.. its silver and has alot of metal tubes going into it. pull the cable out. and your VDC/ABS/TCS will be disabled (along with warnign lights on the dash will be turned on) and you're set.
just rememebr to plug it back in when you're done with whatever you're doing.
Old Aug 26, 2005 | 10:13 PM
benzz280's Avatar
benzz280
Cheston, what is the difference between what you suggested and pulling the fuse?
Old Aug 27, 2005 | 09:58 AM
bio911's Avatar
bio911
has anyone tested this at the track? i didn't feel any difference when i did this...
Old Nov 20, 2005 | 08:41 PM
bmxox's Avatar
bmxox
So pulling the 50amp fuse under the hood disables everything but do you still have brake lights? Ive pulled the 10amp fuse behind the kick panel and it disables everything but you dont have brake lights.
Old Nov 21, 2005 | 07:44 AM
03Z33's Avatar
03Z33
I think the brake lights still work if you just pull the 50amp VDC/ABS fuse ... can't remember since I've had my Yaw sensor disconnected forever now and haven't had to mess with any other fuses.
aarrgghh
May 1, 2022 11:04 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
