FS: NISMO GT Pro LSD
Old May 3, 2012 | 08:21 PM
jnathan68's Avatar
jnathan68
Default NISMO GT Pro LSD
SOLDDD
Used NISMO aftermarket differential. This is the GT Pro LSD that can be switched from 1.5 way to 2.0 way. Was used about 5000 miles before being pulled (car it was in was sold). I had it looked at just to verify and was told it is in good working condition. Only comes with diff and bolts (no carrier/housing, no stub axles, etc.).
Based on research, this will not work with an automatic transmission diff housing or the stock automatic 3.3 gears. You will need a manual transmission diff housing and you will need equal length shafts (from a non-VLSD differential).
Part number is 38420-RSZ15-4U. Link to info http://www.nismo.co.jp/en/products/c...gt_lsdpro.html
SOLDDD
Old May 4, 2012 | 05:11 PM
konrad's Avatar
konrad
would this fit the 3.3 vlsd from Auto transmission?
Old May 4, 2012 | 05:40 PM
jnathan68's Avatar
jnathan68
Have to admit, not sure. Know it will work with a manual trans.
Old May 7, 2012 | 05:29 AM
Ted J's Avatar
Ted J
Depends on what pumpkin it is made for.
If it's from an auto 3.3 pumpkin then it will only work with the 3.3 gears. If it was made for the manual tranny 3.5 pumpkin then it will only work with 3.5 (and other ratios that can be ran with the manual tranny differentials) gears. See the pic I put up in this thread to see why:
https://my350z.com/forum/engine-and-...-pictures.html
Old May 7, 2012 | 06:35 AM
jnathan68's Avatar
jnathan68
Thanks for the info. Based on everything I read about this diff, made for a manual trans only and came out of a manual trans car.
Old May 7, 2012 | 08:43 AM
r1forever's Avatar
r1forever
So I'm guessing it will only work for 3.5 and higher gears. Dam I really wanted this. I have new bearings already too
Old May 7, 2012 | 08:55 AM
jnathan68's Avatar
jnathan68
I know it will only work in a manual differential pumpkin. If you have an automatic with an automatic differential pumpkin, will not work.
If you want to use 3.3 gears in a manual differential pumpkin (manual car), then not sure if there is an aftermarket 3.3 gear set that will work with that setup but might want to research. Stock 3.3 gear from automatic will not work (see link provided by ted j in his post)
Old May 8, 2012 | 08:26 AM
jnathan68's Avatar
jnathan68
More info added. This is a great differential which is hard to find. Z1 is selling this diff for over $2000 (with install kit) so believe my price is pretty fair.
Old May 8, 2012 | 10:05 AM
Playboi12's Avatar
Playboi12
What would I need to install this in a non-vlsd (base model) 350z 6mt
Old May 8, 2012 | 10:55 AM
jnathan68's Avatar
jnathan68
I believe it will install in the base model non-vlsd case with nothing extra, however, I have never done it so you would probably want to check/do some research.
Here is a link to the install https://my350z.com/forum/engine-driv...tall-pics.html
Old May 9, 2012 | 11:58 PM
JustinWong's Avatar
JustinWong
i have a 2005 base manuel Z with a Vlsd....will this fit directly in?
Old May 10, 2012 | 04:05 AM
jnathan68's Avatar
jnathan68
Yes, it will fit in the differential housing but you would need to get the equal length stub axles from an non-VLSD diff.
Old May 16, 2012 | 09:46 AM
NightShade's Avatar
NightShade
Do you still have this? If so I'll take it. I'm kinda stuck, I bought a Quaife which doesn't fit and the distributor/seller won't give me an exchange or refund. So I'm stuck with a $1k paperweight.
(Edit since some people responded about the Quaife)
I got the correct part, so as not to thread jack I'll post my issue in the drivetrain forum.
Old May 16, 2012 | 10:01 PM
Waiz's Avatar
Waiz
Thread cleaned up/closed and infractions handed out
Please report posts in the future if you notice people making unnecessary comments
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
