Car shut down within 5 seconds after I replaced my battery....
one lesson learned today though is avoid CT...and avoid the stealership. Haha best was stealership when i was bored and decided to inquire them for idle pulley/belt replacement....quoted me $900 ;p
One reason why to avoid CT is....do they have the more specific knowledge to fix your problem after just a simple battery swap...probably not. There probably are some very knowledgeable guys at some CT but you'll run into some noobies who have trouble doing a proper oil change.
the solution actually involves midgets hiding in your engine bay and driving around with that midget for at least 1 hour. Just make sure he/she has something to hold onto with 1 hand while the other hand is holding the hood down. okay j/k j/k ;p
ok, here it is
Symptom: Engine stalls on idle rite after engine started
Do the following fix ONLY if you can keep the engine running by pressing a little on the throttle.
FIX
its the carbon deposit that got build-up around the t-body butterfly. Just take off the intake pipe, spray some t-body/intake cleaner around the butterfly. Apply enough just to clean off the deposit around it. Let it sit for 5-10 mins, then starts the engine. The engine will idle funny in the 1st couple of mins(make take up to 10mins) b4 it idles normal. Just let the solvent completely burn off. (
Reason
Seems like the carbon deposit that got build-up around t-plate will get soften and sealed up the 1-2% opened t-plate after entering a warmer climates(shop) from -10C outside.
FIX
Reason
ok, here it is
FIX
Reason
FIX
Reason
Thanks for your tips.
But I am just a bit curious as to why this sympton appeared RIGHT AFTER I swapped my battery..??.. does it have anything to do with the battery that I changed or it's all by coincidence???
um... so I did the re-learning Idle Air Control vale procedure this morning successfully..it seems to get a bit better but rpm still drops to below 500 once in a while.......
anybody knows if cleaning MAF/Throttle body will help resolve this issue?? how much would i be looking at to have these components cleaned by a garage (no dealer for me...)....
Thanks in advance guys..
Robin
Robin
There is an Infiniti dealer that will clean ThrottleBody and MAF for CAD $80? For real?? I thought they'd charge me like $250 or something....
mind to tell me which dealer you went?
...wouldn't it be NICE if car manufacturers simplified all these pain-in-the-neck procedures?! They do all these things to force us to go to the stealership!!! Thank God my Zed resets "automatically" (???) whenever I get a new battery---3, so far.
____________________________________________________________ _______________________________________________________
'O4 Touring Coupe, NO feathering, NO oil-consumption issue, FLAWLESS AT, NO PROBLEMO!!!
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
, if this is the same problem
CT FTMFCW!!!!!
