Amp problems... help!
Old May 4, 2009 | 03:28 PM
vonage's Avatar
vonage
Default Amp problems... help!
Hey,
Just wondering if anyone else who drives a Roadster or Coupe has or had this problem..;
When the music is playing (radio or cd) my sub sometimes turns on and off by itself... It could work for a good ten minutes straight and can just stop working all of a sudden... goes on and off whenever it likes..lol
I was told that it is possibly my amp?!
Is there loose wires? any recommendations on what i can do?
Not sure if it is busted because my sub does still turn on and off... just not consistent..
Some help please!
Old May 4, 2009 | 03:35 PM
kenbo3399's Avatar
kenbo3399
check and see how hot the amp gets, if its really hot it could be shutting off to go into heat protection mode. could be a ground or something too.
Old May 4, 2009 | 05:55 PM
JEFFOS69's Avatar
JEFFOS69
There is also a feature on the deck that raises and lowers volume (bass mostly) depending on road noise - it sucks and doesnt work very well. That may be it too.
Old May 4, 2009 | 07:19 PM
vonage's Avatar
vonage
wow, thanks for the help guys.. i will do all recommendations...
it may be a possibility that it is the ground cuz all the wires connected from amp to sub is fine.. nothing seems to be loose?!
could it be the fuse also?
Old May 4, 2009 | 07:23 PM
kenbo3399's Avatar
kenbo3399
it could be but i doubt it, check the fuse anyway though. make sure everything is connected good cause just cause it looks connected it might not have a secure one.
Old May 4, 2009 | 10:49 PM
david79's Avatar
david79
i have the same problem..someone on this forum suggest its the stock deck..that makes the base turn on and off....
Old May 5, 2009 | 04:59 AM
kenbo3399's Avatar
kenbo3399
what do you mean makes the bass turn on and off? like it will be on and music will be playing and just the base cuts out? are we talkin aftermarket or stock bose?
Old May 5, 2009 | 11:07 AM
david79's Avatar
david79
stock bose...the music still plays but no bass
Old May 5, 2009 | 01:02 PM
aRYip's Avatar
aRYip
I have the same problem either with stock Bose or aftermarket Pionner AVIC...
Old May 5, 2009 | 04:01 PM
kenbo3399's Avatar
kenbo3399
im not really sure, it could be a bad connection somewhere or crimped wire, or something that just went bad. i did some searching and found this thread, hope it helps
http://www.350zmotoring.com/forums/3...tting-out.html
Old May 7, 2009 | 12:17 PM
vonage's Avatar
vonage
Default ...
So i've checked almost everything..
I have a stock bose sub/amp/deck...
I just cant seem to put my finger on it.. it's really getting on my nerves.. took everything out, checked the wires, etc, nothing seems to be loose.. checked the amp to see if there was overheating, which it showed nothing of...
and still the sub (bass) cuts out and comes on whenever it wants..
Old May 7, 2009 | 01:27 PM
kenbo3399's Avatar
kenbo3399
check into the link on my last post. see if theres any info. i didnt look too far into it
Old Jun 12, 2009 | 12:10 PM
DonSupreme's Avatar
DonSupreme
This seems to be a common issue. Is there a known resolution to this problem?
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
