Mossy Short Shifter Information
Old Dec 9, 2004 | 07:48 AM
chachi999999999's Avatar
chachi999999999
Default Mossy Short Shifter Information
There is a group buy on this shifter here https://my350z.com/forum/showthread....67#post1174867 . Here is a little info on the shifter that might get interest in entering the group buy.
Here is a video of the shifter showing all stages.
http://www.imagestation.com/video/p...l?id=4126645402
Here is the info on the shifter.
Position 1 is the highest and equal to 20% longer than stock.(This position is super smooth and very good for everyday driving)
Position 2 is stock.
(This position is if you like stock feel)
Position 3 is below stock and 20% shorter.
(This postion is if you like it a little shorter if you like it a little shorter)
Position 4 is the lowest and is 40% shorter.
(This position is good for racing or if you like it extremely short and is the shortest availiable setting that of any shifter out for the Z)
Old Dec 9, 2004 | 07:53 AM
chachi999999999
Pic 2
Old Dec 9, 2004 | 08:26 AM
MIAPLAYA's Avatar
MIAPLAYA
Hey is that the video I made? Good job...if not heres is my video..
http://www.imagestation.com/video/pl...?id=4142697113
Old Dec 9, 2004 | 09:15 AM
chachi999999999
It is your video that you made. I downloaded it along time ago so I didn't remember where I got it from. My bad. I hope you don't mind me using it.
Old Dec 9, 2004 | 10:40 AM
MIAPLAYA's Avatar
MIAPLAYA
Oh not at all dude. I just wanted to add mine if you didnt have it.
Old Dec 9, 2004 | 12:57 PM
chachi999999999
Thanx man I appreciate it. Actually since you have it, can you tell us a little about it. Do you like it? Which settings do you use and why? Tell us about each setting? Does it rattle? Sorry to bother with all these questions, but it would be great if you could help us out with those questions.
Old Dec 9, 2004 | 02:48 PM
MIAPLAYA's Avatar
MIAPLAYA
I love it...One of the best short shifters I've ever driven. I keep mine on max short...Thats just where like it. The throws are significantly shorter there. Its been there so long driving a regular shifted Z or this shifter in stock mode feels REALLY weird. It does not rattle at all. There was actually an improvement made on the facotry design by the guy who designed this. It solved ALL the rattle there would have been. Plus my wife HATES driving my car at max short (cuz shes used to what her Civic felt like) so she runs it at max long throws and LOVES it. I ust laugh when I see her moving what seems like feet to shift (its not) on max length. All in all its a quality product by someone who knows what hes doing. Also the fact that it is a Solid piece of Stainless ensures you'll break the shift housing and linkage before you break this shifter. I've really wrenched on this thing and havent had a problem with it yet.
Old Dec 10, 2004 | 11:44 AM
chachi999999999
1. Yes, there is still reverse lock just like stock.
2. No rattling!!! There is a change made to an OEM part that is included that keeps it from rattleing.
Guys if you interested let me know in the by the end of Sunday because I may stop the group buy due to lack of interest.
Old Dec 10, 2004 | 11:48 AM
chachi999999999
this is what Company Man from my350z.com had to say:
"This is the only shifter that adjusts both above and below the fulcrum. When you pull up on the release sleeve collar from the highest position, it unlocks the shifter handle and it drops down, lowering the shift **** at the same time lengthening the shifter below the fulcrum, therefore shortening the throw both above and below. The shifter arm is a solid piece of 17-4 stainless steel that is hardened to 40 Rockwell along with some of the important internals. Basically stronger than the same material in a forged steel crankshaft. Your gonna break your arm before you can even bend this baby.
The ability to adjust this shifter to what feels good for you is no different than changing the tilt of your steering wheel. Everyone will have their own preference and not everyone is going to like where you might have it set. What makes this cool is that now, for the first time, you can adjust the height and throw of your stick shift to how you want it.
oh yea, you even get a factory socket.
I'm gonna build one for my ride
225 hp, 500 #tq
Nissan UD 2600 Turbo
if you can't beat'em, crush'em"
Come on guys sign up. The more the better. This is the best short throw for the Z. It is freaken adjustable to 20% longer for smoother shifts for everyday driving or 40% Shorter for racing.
Old Dec 11, 2004 | 09:07 AM
chachi999999999
jason@performan(he works for nissan) from 350zmotoring.com said this about the shifter:
How I feel about it...
This is just my experience with my car / my trans...
At longest setting shifting is effortless... I see this because of the longer shaft on top and shorter shaft on the bottom (longer shaft on top makes it easier to move a shorter shafter the same distance)
But at the shorter setting, shifting is very hard, have to force it into each gear (shorter shaft on top, moving a longer shaft on the bottom means more effort to move the shorter shaft)...
thats it in short...
Old Dec 11, 2004 | 04:17 PM
company man's Avatar
company man
The new adjustable shifter was designed utilizing the stock shift ****. The design was such that when the shifter is adjusted to the stock position, using the stock ****, it has the stock throw. Using other shift ***** will change the design intent.
At stock height, the effort remains the same as stock.
A 20% shorter throw will have a 20% increase in effort.
A 40% shorter throw will have a 40% increase in effort.
If it takes 3 lbs of pressure to move a stock shifter, a 40% increase is 5 lbs. A 20% increase is 3.75 lbs.
If your not strong enough to handle 40%, drop it to 20%. If you can't handle 20%, don't get a short shifter.
This is a straight stainless steel shaft 17-4 and it uses the stock socket. The force from you arm generates direct force to the transmission. If your too whimpy, get an automatic.
Old Dec 12, 2004 | 03:36 PM
chachi999999999
company man said this:
"The new adjustable shifter was designed utilizing the stock shift ****. The design was such that when the shifter is adjusted to the stock position, using the stock ****, it has the stock throw. Using other shift ***** will change the design intent.
This is a straight stainless steel shaft 17-4 and it uses the stock socket. The force from you arm generates direct force to the transmission. If your too whimpy, get an automatic."
Old Dec 13, 2004 | 12:16 PM
chachi999999999
GOOD NEWS GUYS!!!!! I just purchased the shifter. It will ship out soon. I will give a detailed review of what I think of it. Just so you guys know. It still has the reverse lock like the stock shifter so don't worry about accidently throw it into reverse when shifting into 6th. As for rattling, I e-mail Greg at Mossy and asked him what was modified to stop rattling along with other questions. This is what he said:
"Yes I will ship overseas.
The stock ball socket was modified with o-rings.
Miaplaya has it currently installed and loves it. His wife can adjust it up when she gets in, and he can adjust it down when he gets in. It's a beautiful thing, a marraige saver if you will. ;-)
from the machinist:
The shifter lever is a solid piece of 17-4 stainless steel that is hardened to 40 Rockwell along with some of the important internals.
Even though the shifter is adjustable, the 17-4 stainless steel lever is one solid piece with the shifter ball on one end and connected directly to the transmission on the other. Basically stronger than the same material in a forged steel crankshaft. Your gonna break your arm before you can even bend this baby. A stock Nissan shifter socket is included that has been modified for quiet operation.
Thanks,
Greg V
"Speed is money
how fast do you want to go?" "
Old Dec 13, 2004 | 12:24 PM
Diesel350's Avatar
Diesel350
from the machinist:
Thanks,
Greg V
"Speed is money
Are you going to do 1/4 mile runs to see if your times are better?
Old Dec 13, 2004 | 02:17 PM
chachi999999999
Not exactly. I am going to talk about the quality, how each setting feels, and, what seems to be what your interested, the change in speed due to shorter shifting.
Old Aug 1, 2005 | 07:20 PM
cms-35z's Avatar
cms-35z
Bump, did anyone buyone of these and can give a second opinion.
Old Aug 1, 2005 | 08:58 PM
MIAPLAYA's Avatar
MIAPLAYA
I have one and love it. Works perfectly. Quiet good short shifts what more do you want to know?
Old Aug 2, 2005 | 06:27 AM
cms-35z's Avatar
cms-35z
Frankly, I would like an opinion from anyone but MIAPLAYA and chachi.
No offense, but your posts look more like a marketing plug for the product, and I would like for some of the people in the group buy to verify the claims. The videos tell me nothing, cause the car is at a stand still. After 3 or 4 swipes through all the gears while at idle and no clutch engagement the stock shifter can slide like butter as well. I want impressions of the drive, which is the whole point of buying this thing.
thanks,
JC
Old Aug 2, 2005 | 07:39 AM
ezee's Avatar
ezee
The Mossy shifter feels great, adjustability is nice, only problem is it rattles a bit more than stock at high rpm under hard acceleration.
Old Aug 2, 2005 | 08:24 AM
cms-35z's Avatar
cms-35z
Does it act as a quick shifter or is the gearbox still slow to accept gearchanges?
