I think I messed up Badly
Old Dec 28, 2004 | 07:30 PM
supra crazy's Avatar
supra crazy
Unhappy I think I messed up Badly
Hey guys i finally recived my B&M short shifter from the group buy today. After the install i realized that i no longer have to push the shifter down to engage reverse and the shifter also goes a buit past 5th its very scary i think it may have been that i used a dremel to remove the section of the houseing and i may have grinded to much away.
my question is is there a way to fix this or would i need a new transmission.
do you think i could just put a small peice of metel in the gap that i shaved to stop it from goin that far over.
and what do i do about the reverse going in gear with out pushing the **** down?
please help!
Old Dec 28, 2004 | 08:11 PM
ReavTek's Avatar
ReavTek
Sounds like you need to adjust your guide plate. But be aware that the B&M shifter can cause alot of problems. At least in my case it did. I installed one and it was very notchy but much short shifts so I kept it. A few months later it would go past 5th like you stated especially when revving hard. I adjusted the plate and it worked fine but a couple moths later the prob came back and now it seems adjusting the guide plate does not fix it. Needless to say I removed the B&M unit immediately and am looking for a receipt so I can get a refund from B&M. Who knows if it damaged something tranny wise. Right now I'm waiting for some OEM bolts to come in so I can put the stock unit back in and hopefully everything will be fine :/
Old Dec 28, 2004 | 08:15 PM
ReavTek's Avatar
ReavTek
Check Page 8 of this PDF for info on adjusting the guide plate:
http://www.rogueengineering.com/pdf/...er_install.pdf
And no I dont use a rogue shifter... After such a bad exp with B&M I dont think I want to spend another $200 on any short hifter.
Old Dec 28, 2004 | 10:50 PM
supra crazy
Thanks a million i may just take it off and sell it if this doesnt work hopefully the stock shifter will work!
Old Dec 29, 2004 | 12:19 AM
L.A. Roadster's Avatar
L.A. Roadster
Some of the boys at Mossy Performance installed my Nissan Motorsports SS wrong, and my reverse lock out didn't work.
I took it back and they fixed it right away. I realize that this is a different shifter, but they might know how to fix your problem.
If you end up leaving the B&M try the Nissan Motorsports. I'm happy with mine.
Old Dec 29, 2004 | 07:29 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
It should just be a simple adjustment of the guide plate, it's an easy fix.
Old Dec 29, 2004 | 07:54 AM
supra crazy
thanks for the help it was acctually my fault i forgot to reinstall the guid plate i know thats just dumb on my part but every thing works now. Its just really notchy when cold abd i need a new shift **** now i srewed up the stock one because it was so tight on there
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
