unorthodox pulley
Old Jan 1, 2005 | 06:10 PM
columbian frldy's Avatar
columbian frldy
Default unorthodox pulley
i am putting on my new crank pulley, and ran into a problem. The stock pulley wont come off, and i dont want to break some thing by ranking it off with all my might. has anyone done this mod before, that can give me some pointers. Thanks
Old Jan 1, 2005 | 06:22 PM
___DJK___'s Avatar
___DJK___
Are you using a breaker bar?
Old Jan 1, 2005 | 06:30 PM
columbian frldy
ya, it wont budge. hey were you at iin n out today with all the sick cars?
Old Jan 1, 2005 | 06:44 PM
___DJK___'s Avatar
___DJK___
yeah dude, were you there??
Old Jan 1, 2005 | 07:15 PM
columbian frldy
yeah, pm me with your number, i 'll give you a call
Old Jan 1, 2005 | 07:18 PM
2003z's Avatar
2003z
put the car in 6th gear and have someone stand on the brakes with all their might. Then take a floor jack handle and place it over the breaker bar to get more leverage and pull it real hard. Make sure you use a hardened socket, like for an air tool, as I cracked a standard sears craftsman socket trying to get that nut off. You won't hurt the car.
Old Jan 2, 2005 | 05:23 PM
Dissolved's Avatar
Dissolved
the stock pulley wont come off:
Use a pulley puller. Make sure you pull from the center lip of the pulley. Not the one closest to the block. I cant remember if the crank bolt has a dimple or not for easy removal
stock pulley bolt wont come off:
Remove radiator and use an airgun. OR stick breaker bar on ground . Quickly turn the engine by blipping the starter very quickly. This will loosen the bolt.
Old Jan 2, 2005 | 05:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
under no circumstances should you try to engage the starter with a breaker bar connected to the crank bolt...that makes zero sense
if all else fails, use an impact gun.....but there is no need, a breaker bar and the car in 5th or 6th and a strong set of hands is all thats needed
Old Jan 2, 2005 | 06:05 PM
Dissolved's Avatar
Dissolved
really? tell that to my dad who's been a mechanic for over 40 years. It's an old trick. Same principle as an impact wrench.
Did I mention he just finished a 2jz rebuild?
Old Jan 2, 2005 | 06:13 PM
lunartick13's Avatar
lunartick13
A high impact wrench with a range of 250 lbs. torque should pop that baby. IMO specially if the injine is warmed up.
Old Jan 2, 2005 | 06:15 PM
Z1 Performance
Former Sponsor
for a mechanic with 40 years experience maybe it works...for an individual doing this at his house it's a recipe for a trip to the hospital
Old Jan 2, 2005 | 06:23 PM
columbian frldy
thanks guys i got it. the pulley feels great just beat a 390hp wrx. on a 100 octane. (:
Old Jan 2, 2005 | 06:24 PM
Dissolved's Avatar
Dissolved
How?
Lay the breaker bar on the ground. You sit in your car and blip the starter. Have someone use a stick to make sure the socket stays on the bolt. Positive pressure is applied towards the ground.
Old Jan 13, 2005 | 05:16 PM
350Z-VDC=Bandit's Avatar
350Z-VDC=Bandit
what direction does the motor rotate, so that bar doesnt come flyin off lol? that is the stuff that the mechanic will think about not the DIY'er lol. its cool but I would rather use the impact wrench or better yet get someone with some skills do do it..... like your dad.
also you should remove the sparkplug wires so the car doesnt start after you "blip" the starter.
later,
Scott
Old Jan 13, 2005 | 06:11 PM
2003z's Avatar
2003z
later,
Scott
actually, just need to pull the fuel pump fuse in the battery compartment, we don't have spark plug wires.
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
