JWT or Nismo Cams?
Time for a round of internal mods... going to do the Cams plus a 3.917 final drive... one Q, (well, other than which cams set to choose
), should I get the high-lift valve springs at the same time? Thanks in advance,
-nick
), should I get the high-lift valve springs at the same time? Thanks in advance,-nick
-nick
might as well add on the espirit and tomei cam sets as well...
thanks again,
-nick
the engine wouldnt need to be pulled. But you should be able to get the headers on for a cheaper price at the time of the cam instal. since the engine will be torn apart, the headers will be easier to get to and take less time.
Originally posted by Z1 Performance
you dont need springs with either of them.
As for which to choose, they are nearly identical, so you cannot go wrong with either set
Z1, i'll throw on some of those UR high-flow cats you've got while i'm at it!
