My Z just lost 20 lbs of fat in less than 1 hour, installed Hawker PC680 Race Battery
Thanks very much to MySunset350Z -- who sold me the battery his fabricated "home depot" style brackets for a great price. I made a couple of small improvments to the brackets (added an L-Brace to better hold down the battery) and did some dremel work on the battery tray bracket.
But overall the install was super easy thanks to Sunset's brackets. Thanks buddy!!!
I plugged everything in and the car fired right up. I think with this mod I may be below 3100 lbs.
I will need to weigh everyhthing latter. BTW, I weighed the battery, brackets, screws and all other hardware for the install on my bathroom scale -- 15.8 lbs.
As I understand the stock battery is 36 lbs. Net loss 20 lbs.
Finally -- does Pep Boys accept old batteries? The stock battery is practically new. But I don't really want a plastic box full of acid that emits explosive gas in my condo. If anyone wants it -- it's theirs. Just come get it. Otherwise, I will try to see Pep Boys will accept it for recycling.
Coming -- like a dummy, I was half way through the install and remembered to take pics.
But I did snap some -- then left the camera down in the car.
I used this post as a reference for the install.
Link to Post
This shows a bottom mounting bracket very similar to the one that Sunset sent me. I did a little touch up on it with my Dremel to make it fit better -- but otherwise it's exactly the same.
Link to Post
been using the 680 for almost a year
20lbs off the front is great, very few mods has a better $ to lbs ratio.
I was able to fit mine without modifying anything.
what are you other weight reduction mods if I may ask? (beside the obvious SSR)
Also, why did you tape your car blue? chips?
SSR's (-25lbs about -6 lbs a corner)
Spare Tire and tool removal (-40 lbs)
Rear trunk mat removed (-8lbs)
Battery (-20lbs)
Stoptechs (-0 lbs because I did the 14" kit --
350Evo Sways (-?? lbs)
I have the Enthusiast which is light to begin with (3188 lbs). I figure I am down close to 3100 lbs or less (but I have not put the car on a scale yet).
Battery (-20lbs)
)350Evo Sways (-?? lbs)
aftermarket seats don't save much total weight - maybe 10-15lbs because the mounting brackets are heavy as hell
the 350Evo sway bars are lots heavier than stock - I have them, trust me they're heavier
spare tire and tools is more like 35lbs
i'm not sure how heavy the rear trunk mat is in some Z's, but mine weighs probably a hole couple lbs
Originally posted by nuff
Get some bucket seats, that should drop a fair bit of weight, there's not much else at the front, also flywheel might help.
real race bucket seats without a rollcage are a death trap. I also have side imact airbags on stock seats that I don't want to get rid of.
my weight saving up to now
~25lbs BBS rgr (6lbs per corner with wheels)
~20lbs Battery
~10(?)lbs injen SES
~5(?)lbs gruppe M intake
~ 40lbs spare tire and everything
~ 10(?)lbs other general stuff... (like all the plastic in engine bay, floormats, trunkmats, etc....)
I have more than 110lbs saved easy. Trying to get to 200lbs... which will require more hardcore solutions.
he has his car taped to protect it from chips, and when racing hard you tend to send a lot of rubber all over as your tires heat up, and get soft (especially street tires- i have gotten them so soft that they suck up every rock and my fenders and wheel wells are covered).
i usually just taped up the turn signals and fogs so that they wouldn't shatter if hit with a rock (some tracks make you do this). i seemed to get a heck of lot of chips on my car racing. some tracks are pretty bad. i had to get a front lip repainted yearly........ well sometimes twice a year when i had to get a new one after killing peter cotton tail with it once.
i always used ultima batteriers. nice small and light. it is a great way to trim weight.
Originally posted by sentry65
why are real race bucket seats without a rollcage a death trap?
With a race bucket seat, it will be your cranium and spinal cord that will collapse before the seat does. Then you get to eat with a straw for the rest of your life.
roll cages are heavy though
I agree with Skrill that it's the 5/6 point belts that will hold you in place and kill you in the case of roof caving in. The 5/6 point belts will kill you also with stock seats. If you use the stock seat belt with bucket seats you'll be fine.
By the way Skrill, can we see photos of the finished install. Thanks
