350EVO Solid Transmission Mount
Old Feb 7, 2005 | 10:45 PM
sentry65's Avatar
sentry65
the burninator
Default 350EVO Solid Transmission Mount
what are your guy's thoughts on this?
how hard/much/long is it to install it?
http://www.350evo.com/catalog/produc...28e859fa3add69
Old Feb 8, 2005 | 06:52 AM
Thunderbolt's Avatar
Thunderbolt
Charter Member #88
You will need solid motor mounts too. If the motor can flex on its mounts and the transmission can not, you can break the transmission housing. I have seen this happen many times on local race cars
Old Feb 8, 2005 | 09:18 AM
MY350Z.COM's Avatar
Solid motor mounts would rattle your teeth out!
Hardened rubber or urethane would be better.
Victor
Old Feb 8, 2005 | 05:12 PM
jreiter's Avatar
jreiter
Victor
Agreed. I'd be all over some stiffer engine/tranny mounts, but no one seems to make them. (Not that I can find, anyway.)
Old Feb 8, 2005 | 05:27 PM
sentry65's Avatar
sentry65
the burninator
what's involved in installing it?
Old Feb 8, 2005 | 08:12 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Im sorry to say but if you thought the tilton chater or flywheel chatter alone may be something that is anoying you do NOT want this...
Some of my friends you have it... well should say had it took it out because it made their car very uncomfortable to drive...
loud / vibraty
Old Feb 9, 2005 | 04:45 AM
TheBigShow's Avatar
TheBigShow
if u drive more than 50 miles a year, don't worry about mounts.
Old Feb 11, 2005 | 05:29 AM
mena661's Avatar
mena661
I had polyurethane motor and tranny mounts in my old car. There was a lot of vibration at idle and even more at idle with the AC on. When the car was moving there was no vibration I could feel. The car was pretty solid cause there were no rattles or squeaks but YMMV on that. It never really bothered me and after a while I didn't notice. My wife didn't like it though. I figured the ride (coilovers) would bother her more than the vibrations but that was not the case.
Old Feb 11, 2005 | 01:17 PM
dklau33's Avatar
dklau33
Yup, I had ES polyurethane motor mounts and suspension bushings in my former Eclipse and it caused quite a bit of vibration into the cabin at idle. Worse with the AC condenser running. So I could only imagnine what a complete solid mount would do! If you value your comfort you won't do this mod. More for race cars and not daily drivers.
Old Feb 11, 2005 | 01:57 PM
sentry65's Avatar
sentry65
the burninator
so obviously no one would do it for their street car.
how much noticable is it? I mean it is like recovering 5% of your lost hp in the drivetrain?
Old Feb 11, 2005 | 05:04 PM
mena661's Avatar
mena661
My last car was a street car. The throttle response was better and you didn't feel any jerking under sudden deceleration.
Old Feb 12, 2005 | 01:19 AM
jreiter's Avatar
jreiter
Like Mena said up above, I can't imagine you'd gain any power. It would be improvements in throttle response, and a lack of jerking around that you'd gain.
Old Feb 12, 2005 | 01:20 AM
jreiter's Avatar
jreiter
Does anyone even make poly mounts or even hard rubber mounts for the Z yet? Anything that's stiffer than the stock fluid-filled mounts, but not as hardcore as a solid mount.
Old Feb 14, 2005 | 10:00 AM
wfcall's Avatar
wfcall
Hey guys, Thought I would throw my two cents in from past experience.
A solid transmission mount without solid motor mounts WILL break something; you would be essentially using the transmission mount and transmission housing to hold the motor from twisting; placing way too much stress on it.
Solid motor mounts by themselves will not risk any damage to the transmission.
whatever you end up with in the way of mounts the motor mounts MUST be equal to or greater in rigidity than the transmission mounts.
Old Feb 14, 2005 | 10:03 AM
wfcall's Avatar
wfcall
Oh and BTW----I installed solid mounts on my Yamaha V-MAX and the rear view mirrors are now useless and my hands go numb after about fifty miles. On the good side the more rigid frame created by the mounts made a huge difference in high speed handling.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
35reilly
Sep 28, 2015 07:42 AM
