need help on technosquare reflash
Old Feb 17, 2005 | 05:01 PM
newbie's Avatar
newbie
Default need help on technosquare reflash
is there any thing i can ask technosquare to do with my ecu other than Fuel Map,Ignition Timing Map , Speed Limiter ,Rev limiter ,Variable Timing Control ??
how about adjust the throttle body to open at 100%?
anything i'm missing?
and will it be better that i'm given technosquare my a/f ratio? or even a a/f graph ?will it be better if i send them the graph instead of just the #s?
thanks for any help guys
Old Feb 18, 2005 | 05:29 AM
SungNamZ's Avatar
SungNamZ
What sort of mods have you done or plan on doing?
Old Feb 18, 2005 | 10:02 PM
GY-Z's Avatar
GY-Z
are you gonna mail your ecu in? or you locate near technosquare?
Old Feb 19, 2005 | 12:20 PM
newbie's Avatar
newbie
i have exhaust, ypipe, testpipe, header, and intake.
newbie's Avatar
newbie
mail in.
Old Feb 19, 2005 | 12:38 PM
GY-Z's Avatar
GY-Z
i think the most stuff you can do is the F-Spec, which includes
REV limiter modification, Speed limiter removal, Ignition time and fuel timing map adjusted, adjusted the correction factor to reduce that compensation reaction for a intake/exhaust mode, and adjust the TS to open up to 100%.
did i missed anything?
Old Feb 22, 2005 | 04:14 PM
newbie's Avatar
newbie
anyone else can confirm?
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
exploder
Feb 6, 2004 01:56 PM
Chebosto
Northern California
May 21, 2003 08:59 PM
