Gauge Install help (SPA)
Old Feb 25, 2005 | 12:08 PM
webrits's Avatar
webrits
Default Gauge Install help (SPA)
I'm looking for a little help with installing my sensors for a SPA dual gauge - Boost / Fuel Press.
The sensors are identical as they are both measuring pressure and have a 1/8" BSP thread (I believe they will also fit 1/8" NPT).
Where is the best / easiest place to install these?
Is there some kind of adapter I can use to tap into the fuel line and where should I install it in the fuel line? After the regulator?
Will I get an accurate reading installing the boost gauge after the intercooler? Or should it be installed in the intake manifold? Anywhere else I can install the boost sensor?
BTW - I have a Vortech installed.
Thanks......
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
