Grounding Wire Kit. Voltage Stabilizer Kit. What's The Difference?????
Old Mar 17, 2005 | 07:25 AM
Zardoz's Avatar
Zardoz
Question Grounding Wire Kit. Voltage Stabilizer Kit. What's The Difference?????
I'm ordering Z-Extreme's 7-wire, 350Z Grounding Kit.
I also came across this: Voltage Stabilizer Kit (link). One cable connects to the positive battery terminal, the other connects to the car chassis ground.
Could I use both of these at the same time?
Z-Extreme's kit also has a chassis ground wire, so I wonder if connecting them both up could be dangerous? My car is completely stock. No mods yet, if that helps any. Any help woul be greatly appreciated.
Old Mar 17, 2005 | 10:28 AM
MY350Z.COM's Avatar
Voltage stabilizer kits seem to be BS to me. If you open up those boxes it contains a tiny loops of wires and a fuse.
It's been investigated before.
Old Mar 17, 2005 | 11:45 AM
Zardoz's Avatar
Zardoz
I tried searching for it without avail, but thanks M.W. I knew that sounded too good to be true.
Old Mar 17, 2005 | 11:50 AM
350Z-VDC=Bandit's Avatar
350Z-VDC=Bandit
hey that voltage stabilizer box is some BS someone on here cracked the case and looked at the "secret technology". BTW a 7 wire grounding kit is not going to show much improvement over a 5 or a six so if your paying more than 5 dollars more for that 7wire its not worth it imo.
Later,
Scott
sales@czp
Sep 23, 2019 03:30 PM
