OBDII code: P0051?????
Old Apr 5, 2005 | 07:34 PM
ztropic's Avatar
ztropic
Default OBDII code: P0051?????
I've had an SES light on since I've put on my headers two months ago and it won't go away. I've reset the ECU numerous times, but it always came back, so today I bought a code scanner and I pulled this code... P0051 (H025 Bank 2 sensor 1 heater circuit low). What the hell does that mean? I know it has to do with my upstream O2 sensor on the 2-4-6 cylinder bank. Does this mean that particular O2 sensor is bad? If anyone has any insight on this please let me know.
Old Apr 7, 2005 | 05:55 PM
ztropic's Avatar
ztropic
Anyone?
Old Apr 7, 2005 | 06:09 PM
westpak's Avatar
westpak
SFZCC
If it is code P1051 there is a bulletin for it NTB04-072
Old Apr 8, 2005 | 03:28 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
What's the bulletin?
Old Apr 8, 2005 | 05:38 AM
westpak's Avatar
westpak
SFZCC
If you want I can email it to you.
Old Apr 9, 2005 | 02:52 AM
ztropic's Avatar
ztropic
westpak,
It's not P1051, but P0051. Do our cars have heated oxygen sensors? I'm assuming they do (in an attempt to speed up ECU readings (better fuel efficiency)). Apparently oxygen sensors need to to be around 600 degrees to start functioning in a closed loop with the ECU, so if that is true, then the code I'm reading must be indicative of a short in the heater circuit or a failed wire or connection. Does this make sense?
Old Apr 9, 2005 | 03:45 AM
westpak's Avatar
westpak
SFZCC
Well I guess it depends what year car it is if it is an 03 then P0051 if probably for a bad oxygen sensor heater if it is an 04 or 04.5 not sure where the chabge happened it would be code P1051 and it would be a bad AF sensor heater, they changed from oxygen sensors to af sensors.
Old Apr 9, 2005 | 09:28 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
That's why I asked. In my 03, I have a constant CEL and when I read it with my Digimoto software on the OBDII, I get the heated O2 sensor code.
Catagory: Powertrain
Description: HO2S Heat
It didn't happen until after I installed my supercharger but it didn't happen immediately though. I happened shortly after I installed my ZR3 Laser Shifter last summer. This was just before I had the new fuel system installed so it wasn't that.
It's still on to this day but I've had no problems at all.
Just a side note on a similar subject. I've had my aftermarket wheels/tires on now for a few weeks and my TPS warning light has never come on. I was told that it'll come on and stay on after you got rid of the stock wheels/tires and the TPS sensors. ???
Old Apr 9, 2005 | 05:44 PM
350ed's Avatar
350ed
Professional
You generally have to drive for an hour or so before it starts being upset for the TPS missing. Which works out well for most of us
Old Apr 9, 2005 | 06:58 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
An hour? Ok, than that's why I haven't seen it yet. I guess when I make the trip down to ZDayz, I'll be seeing that baby most of the way then.
Workshop12
Mar 23, 2020 01:45 PM
wayneside
North West
Sep 23, 2015 02:23 AM
Detailed Image
Cleaning & Detailing
Sep 18, 2015 11:43 AM
