Stillen Engine Dampener: Install and Review
Old Jul 6, 2006 | 09:19 PM
  #41
BlueDragonZ's Avatar
BlueDragonZ
Originally Posted by THE TECH
It is a pretty easy install aside from the tight spaces that require a bit of patience. All you need is a couple of sockets and a long allen wrench.
Cool thanks. I looked at where it was being installed today and I need to get some tools.
Old Sep 28, 2006 | 05:17 PM
  #42
davewo's Avatar
davewo
Originally Posted by Zquicksilver
If you want a 100% trouble free install, go with the Stillen or other. If you don't mind drilling a hole in one of the steel plates provided in the Ebay kit and buying a slightly longer strut bar bolt, buy the EBAY one. I installed mine when I installed the AAM spacer and reinstalled the strut bar. Both Dampeners are most likely manufactured in CHINA, maybe at the same plant ...I've seen crazier stuff over there when visiting for work.
Bottom line, the engine moves a LOT less when properly installed and shifting has become extremely precise. No extra vibrating in my particular case. Not bad for $49 to my door.
Zquicksilver
Sorry to dig this thread up.
Does anyone have instructions and pictures? the links are dead. Ebay product does not have instructions.
Old Sep 28, 2006 | 08:21 PM
  #43
davewo's Avatar
davewo
Default Stillen Dampener with APS TT
Is it possible to install the Stillen Torque Dampener with the APS TT? There seems to be a pipe that runs right where the dampener is suppose to be.
Old Sep 29, 2006 | 07:48 AM
  #44
THE TECH's Avatar
THE TECH
The picture that you show is not the Stillen damper. The Stillen mounts in a totally different spot.
Old Sep 30, 2006 | 11:51 AM
  #45
Triple8Sol's Avatar
Triple8Sol
Best Deal on the Topspeed Pro-1 engine damper:
https://my350z.com/forum/showthread.php?t=189741
Old Oct 4, 2006 | 04:50 PM
  #46
Zquicksilver's Avatar
Zquicksilver
When I mounted that EBAY TD, I did it in hast without thinking... it's deluboyz or something torque damper. He is literally sourcing a direct copy of the Stillen one now
Anyway, when I first picked this up it just had two steel plates in the kit, so I did what I could. That picture depicts an INCORRECT way of mounting it. It's not effective! A while back one of the guys brought this to my attention, so I re-considered things and discovered another way of mounting it. 5x more effective!
What I need to do now is talk to Hydrazine about creating a product using this mounting technique. It would clear just about everything and not put repetitive stress on ONE mounting bolt, like Stillen's TD does.
I did this because of my headers, HFCs and exhaust... I was trying to reduce repetive twisting caused by the soft engine mounts. It seems like it's decreased movement by about 50% or more. The engine will always flex some, because the TD flexes internally due to the rubber bushings.
Too be continued...
Zquicksilver
Old Oct 16, 2011 | 05:52 AM
  #47
phreaktor's Avatar
phreaktor
Design Engineer
Sorry for the old bump, but can someone rehost the pictures please?
Old Oct 20, 2011 | 06:35 AM
  #48
kacz07's Avatar
kacz07
Phreak, talk to Dr. Venture. I'm pretty sure he has this piece installed on his car.
Old Oct 23, 2011 | 10:57 AM
  #49
lambo4life55's Avatar
lambo4life55
If anyone is looking for install instructions just go to Stillens website, click on the engine torque damper and to the left of the part number there will be a little wrench which are the install instructions from stillen.
p.s. the sidenote says these will not work for 2007 Z's, I dont know how true this is.
http://www.stillen.com/product.asp?i...SAN&model=350Z
Old Oct 23, 2011 | 04:42 PM
  #50
Dan Garcia's Avatar
Dan Garcia
I got the instructions for 07-08 install, if anyone needs them just let me know and I'll get them scanned and sent to you.
Old May 29, 2012 | 03:30 PM
  #51
ronn1's Avatar
ronn1
Will this fit under Nismo Intakes? There is a solid pipe with Cone filter and heat shield that might get in the way.
Here is Nismo set up:
Here is Installation Guide:
http://www.stillen.com/product_files/307360~inst.pdf
nanotech
Oct 2, 2015 05:02 AM
