The AAM Spec Summer Horsepower Drive!
Old Apr 29, 2005 | 02:47 PM
dynamic6er's Avatar
dynamic6er
Default The AAM Spec Summer Horsepower Drive!
After countless requests we have decided to present a second and last opportunity to purchase an Angled Plenum Spacer at a discounted price of $219. To achieve this price we need 20 people to sign up, and this is a first come first serve opportunity – when we run out of spacers it is over. We will NOT be adding more orders like we did last time; and everyone can expect a quick turn around. This will be our last planned discount and all future spacers will be offered at the $249 retail price.
The proprietary AAM Angled Plenum Spacer is a Highly Engineered and Quality Built product that offers on average 8 to 15 RWHP. This is a HUGE bang for the buck! The AAM Spec Angles Spacer allows retention of the stock strut tower brace, the stock engine cover, and is easy to install.
We include a complete set of hardware for proper installation and utilize an OEM gasket to ensure proper sealing.
We are also offering 4 bolt on packages that offer anywhere from 10 to 40 RWHP over stock!
AAM Spec Stage1
-AAM Spec Angled Plenum Spacer
-AAM Spec Y-Pipe
$748 Regular Price
$619 HP Drive
AAM Spec Stage2
-AAM Spec Y-Pipe
-AAM Spec ECU Flash
$1343 Regular Price
$1119 HP Drive Price
AAM Spec Stage3
-AAM Spec Y-Pipe
-AAM Spec Cat Pipes*
$1047 Regular Price
$869 HP Drive Price
AAM Spec Stage4
-AAM Spec Y-Pipe
-AAM Spec ECU Flash
$1642 Regular Price
$1359 HP Drive Price
Package Specifics
AAM Spec ECU Flash:$595 Regularly
One of the simplest ways to upgrade the performance of your Nissan 350Z or Infiniti G35 is to have the factory computer reprogrammed for optimal performance. The Nissan 350Z and Infinit1 G35 run extremely lean under WOT (wide open throttle) from the factory. Through enhanced ignition mapping, adjusting the fuel map, eliminating the speed limiter, and raising the REV-limiter to ~7100rpm our customers enjoy more power, economy, and reliability. Expect a gain between 8hp and 16hp depending on the vehicle.
If you live near Altered Atmosphere Motorsports flashing is a straight forward process. Simply drive over, we’ll link to your factory computer via the OBDII port, and reprogram your ECU - takes about 30 minutes from start to finish. If you are not local, removal of the ECU is straight forward and takes about 15 minutes. The ECU can then be shipped to us for programming. ECU’s that are shipped take top priority and normally have a same day or one day turn around. After countless hours of R&D, Dyno testing, and road testing AAM has perfected programs for the 350Z & G35 from stock vehicles to slightly modified vehicles to supercharged & turbocharged monsters. We also offer custom programming for anyone who has specific requirements. Give us a call 301.330.8835 or e-mail MikeM@alteredatmosphere.com for more information!
Angled Plenum Spacer:$249 Regularly
10-15 HP, 30 Minute installation, less then the cost of your average intake filter kit! The all new proprietary AAM Angled Plenum Spacer for you G35 and 350Z is the ultimate upgrade in the quest for more power – and the ultimate bang for your buck! The 6061 billet aluminum angled plenum spacer sits between the factory upper and lower plenum, allowing a larger volume of air to the cylinders. Power increases across the board and the upper RPM range screams! Works with the factory engine cover (no modifications necessary) and your factory strut bar (350Z) for a stellar install. Reserve your spacer while they are still in-stock!
AAM Spec Y-Pipe: $499 Regularly
Constructed of 16-gauge T-304 Stainless Steel to ensure the highest reliability, quality, and performance, AAM is proud to announce the release of its Y-Pipe for the Nissan 350Z and Infiniti G35. Using smooth 2.5" mandrel bent tubing and stainless steel flex joints which flow into one large 3" tube, the AAM Spec Y-Pipe improves upon the factory Y-Pipe's restrictive design by allowing a substantial increase in the mass of exhaust flow, and reduces the backpressure and thermal stress, which helps to unleash the engine's potential for increased power and torque. Dyno tested on a near stock 2004 Nissan 350Z, the AAM Spec Y-Pipe gained 8 RWHP in comparison to the factory Y-Pipe! Don't be fooled by competitors designs which commonly use 18 or 20-gauge tubing that is prone to cracking, and use non-stainless steel (if any) flex sections. The AAM Spec Y-Pipe is a direct bolt-on upgrade that requires no modification of any factory components.
AAM Spec Cat Pipe (off-road use only!): $299 Regularly
The highly anticipated AAM Spec Cat Pipes for the Nissan 350Z and Infiniti G35 are finally here! After servicing and installing several of our competitors’ designs we decided to make a higher-quality cat pipe that meets the demanding reliability expectations of our customers. In addition to having poor fitment, many of the cat-pipes on the market are constructed of thinner, lower grade stainless tubing. Not only are these units highly susceptible to fatigue and cracking on near stock 350Z's and G35's, some customers with supercharged and turbocharged 350Z's have torn apart the weld joints of these inferior cat-pipes. Made out of 2.5" mandrel bent 16-gauge 304 stainless steel to ensure the highest reliability and quality, the AAM Spec Cat Pipe replaces your vehicles restrictive factory catalytic converter to allow the highest possible exhaust flow. Dyno testing has shown 8 to 10 RWHP gains on a near stock Nissan 350Z and 20+hp gains on a turbocharged Nissan 350Z! The AAM Spec Cat-Pipes are for off-road use only and are a direct bolt-on replacement of the factory cats.
HP Drive Guidelines
-Offer Ends 5/14/2005
-No refunds or cancellations on HP Drive Orders
-All payments must be received no later than 5/21/2005
-Shipping charges will be determined at the time of sale
-Credit Card Payments can be made over the phone 301.330.8835 or Paypal (lotoboost@aol.com)
Old Apr 29, 2005 | 05:03 PM
Mantis3024's Avatar
Mantis3024
Put me down for a spacer
Old Apr 29, 2005 | 07:23 PM
chazzg's Avatar
chazzg
I want one as well, let me know how to pay you and when i can get it.
Old Apr 30, 2005 | 05:19 AM
NA&CH's Avatar
NA&CH
Can I get a price for spacer and cat spec pipes. Package deal.
Put me down for one spacer. and where to send the money.
after watching the last gb go down this is me.
Old Apr 30, 2005 | 05:27 AM
teh215's Avatar
teh215
I thought that this tread was going to be about a cruise
Old Apr 30, 2005 | 07:43 AM
dynamic6er's Avatar
dynamic6er
-Mantis3024(Spacer)
-chazzg(Spacer)
-Turbogt(Spacer[maybe cat deletes])
Old Apr 30, 2005 | 07:44 AM
dynamic6er's Avatar
dynamic6er
Cruise with extra power!
Old Apr 30, 2005 | 11:21 AM
chazzg's Avatar
chazzg
Never mind, I found one cheaper from another Member
Old Apr 30, 2005 | 05:03 PM
doo925's Avatar
doo925
Default AAM Spacer Deal
Please put me down for 2 spacers. Thnx
Old Apr 30, 2005 | 07:55 PM
Sins4u33's Avatar
Sins4u33
BUMP for some kick *** power!
got the test pipes and i love them, stock exhaust SCREAMS...
Old Apr 30, 2005 | 09:28 PM
NA&CH's Avatar
NA&CH
Is there anyway to buy early? thanks cant wait
Old May 1, 2005 | 04:14 AM
DomZ's Avatar
DomZ
You can count me in for a spacer, but you won't receive payment until 5/7/05 (next payday) if that's ok. (It says 5/21/05, but just making sure). Also, can I get a price for the test pipes + spacer package deal as well?
Old May 1, 2005 | 10:24 PM
Sins4u33's Avatar
Sins4u33
-Mantis3024(Spacer)
-DomZ(Spacer)
Me or Dave will send you a PM in a bit on the package your interested in...
Cant miss out on these packages guys, i know alot of people were still interested in the spacer...
BTW a member on the boards here known as Solrac has all of these parts on his Z, he is making about 260whp and about 245ft/lbs of torque, he's very happy with the power he is making with our parts, im sure he will chime in with his thoughts and comments when he see's this thread...
Ben Y
AAM
Old May 2, 2005 | 04:08 AM
Solrac's Avatar
Solrac
OMG this is the best second chance deal of a lifetime!
I have all the AAM spec parts and the upgrade done to my 04 and it definately is the cheapest way to go for some real power! Just with the spacer on, I felt my tires slip a lot easier when I gunned it. Now with the Y-pipe and the test pipes and ECU, it noticeably adds more pull in the high end RPMS, and it sounds REALLY nice after about 3500 RPMS.
The sound of the test pipes emphasizes the natural exhaust tone of the Z and makes it sound a lot more aggresive. I love driving around in the high rpms with the windows down just to hear it!
Old May 2, 2005 | 06:12 AM
jdifolco's Avatar
jdifolco
I'll take a spacer. PM me with any info I need.
Old May 2, 2005 | 09:07 AM
Mantis3024's Avatar
Mantis3024
Id love to hear how the test pipes sound. Hey Ben, are you going to the meet this Saturday at College Park?
Old May 2, 2005 | 09:31 AM
NA&CH's Avatar
NA&CH
Solrac. Is that with the stock exhaust out the back? I am about to order some parts. As mantis said some sounds would be awesome.
Old May 2, 2005 | 11:01 AM
black350's Avatar
black350
want to buy, though i need to know how you guys make it all fit under the hood...are there added spacers on the hood n strut bar??
Old May 2, 2005 | 11:05 AM
Solrac's Avatar
Solrac
Yeah, I still have the stock exhaust. Only parts that have been changed, are the Y-pipe and the test pipes. I'll try to be at the next meet if you guys wanna hear it.
Old May 2, 2005 | 11:39 AM
MastaKillaZ's Avatar
MastaKillaZ
Count me in for the spacer too... PM me with info on payment and so forth
