twin turbo problem starting please help!
Old May 22, 2005 | 06:36 AM
st350z's Avatar
st350z
Default twin turbo problem starting please help!
the car has the greddy twin turbo kit. every time I go to start the car it cranks for a long time and I have to hit the gas pedal a couple times for it to start. the odd thing is it all was starts. If I leave the car for two days with out starting it then it starts up no problem. please help
Old May 22, 2005 | 06:49 AM
350G's Avatar
350G
I used to have a similar problem with it starting, but has not shown up for about 8 months now--only in the first few months after install. Have you had the vehicle tuned? I'm guessing the rich maps make it harder for the vehicle to start.
G
Old May 22, 2005 | 08:06 AM
bullseye's Avatar
bullseye
Years ago, I had a 1979 2.3L Rustang Turbo that did the same thing, which was diagnosed as vapor lock. The engine got pretty hot, which made restarts difficult. Cold starts were absolutely no problem. The car was wrecked and totaled-out before I had a chance to do anything about the vapor lock. I was glad to get rid of that car... It was a horrible piece of junk.
Old May 22, 2005 | 08:58 AM
G3po's Avatar
G3po
a) How cold are your plugs? If too cold ,they can get fouled under street use.
b) has the TB been unplugged, if so it may to go thru the TPS training proceedure.
c) a small vaccum leak could cause starting issues,once hot leaks often seel up and only exhibit symptoms after a cold soak cold. If you have a boost vac guage you would prolley see erratic needle movment just after cold starting.
d)Some times low battery voltage on a modern system can cause starting issue. I've found this on car that sit for long periods unused.
Lots of possibilites...
Old May 22, 2005 | 10:52 AM
st350z's Avatar
st350z
the car is running one range colder plugs, but it was starting like that before the new plugs. I am running on greddys stock program. can a msd ignition help.
Old May 22, 2005 | 11:03 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
always had that problem with my stock motor with greddy tt
with built motor, aam fuel system, and rich map..must floor gas pedal quickly while turning key- motor starts right up every time
my understanding:
the ecu has a seperate area that controls fuel on startup, seperate from fuel through driving- so, adding fuel with emanage to the map will not fix the problem...what fuel system are you running? stock?
probably have to just live with it...if you floor thepetal once--to allow some air in--does it start immediately?
Old May 22, 2005 | 11:05 AM
st350z's Avatar
st350z
just fuel system no pump or rails. did not want to do that until I can solve the starting problem, us less that well help.
Uriyo_
Sep 8, 2021 08:46 AM
