JWT weight
Old May 24, 2005 | 11:18 PM
itsjoshufocker's Avatar
itsjoshufocker
Default JWT weight
how much does the clutch flywheel combo weigh compared to the stock clutch and flywheel? im thinking about getting just a flywheel.. but if its a significgant weight loss, i might just get both!
Old May 25, 2005 | 08:32 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I've heard that the JWT Flywheel (14 lbs) and Nismo clutch is the lightest combo besides the tilton I just went with JWT for both, since I like to keep it synonymous as much as possible.
Old May 27, 2005 | 08:23 PM
Armitage's Avatar
Armitage
Stock flywheel, IIRC is 28 lbs. I believe the clutch is the same weight, because they say the Tilton combo is 16 lbs total (8 for the flywheel, 8 for the clutch) and saves 40 lbs over the stock configuration. That would put the OEM setup at 56 lbs.
You can do the rest of the math.
Old Jun 5, 2005 | 08:02 PM
illZ's Avatar
illZ
Holy smokes..
I wonder the mass of the ORC and Exedy.
sales@czp
Sep 23, 2019 03:30 PM
B Esquire
Sep 24, 2015 07:52 AM
