Stroke changes?
Old Jun 18, 2005 | 07:28 AM
bullseye's Avatar
bullseye
Default Stroke changes?
I know folks are building bottom ends for high boost. Forged pistons, providing lower C/Rs, are common fodder. Forged rods are common, too, but what about the length of these aftermarket wonders? Are they the same length as OEM rods, or are they longer/shorter to change torque and/or HP output in and of themselves? Has any research/experimentation been done in this regard?
Thanks.
Old Jun 19, 2005 | 07:46 AM
bullseye's Avatar
bullseye
Bump...
Old Jun 19, 2005 | 08:03 AM
g356gear's Avatar
g356gear
Thanks.
Stroke is maintained with the aftermarket rod/piston combos. You go to the AEBS stroker kit with low compression and FI if that is the direction you want to go. There are a few AEBS blocks on the board and 1 or 2 with the stroker kits as well.
350zJIM
Sep 12, 2004 04:19 PM
