Removing the fuse for the VDC/Traction control safe?
Old Mar 4, 2006 | 08:11 PM
  #41
Fletch69z's Avatar
Fletch69z
Does Chebosto's way disable the brake lights? And it does disable ABS right? I will try it tomorrow when it's light outside and post up what I find out.
Old Mar 5, 2006 | 05:54 AM
  #42
MustGoFastR's Avatar
MustGoFastR
Originally Posted by meatbag
Shouldnt you just cut the orange wire and put the switch inline and thats it?
Yup, very easy. Somenody's already done it; there's a DIY with pics in the interior/exterior mods section someplace; do a search. Also check out the VDC disable threads in the general section.
Old Apr 4, 2006 | 03:18 PM
  #43
dlt1cy's Avatar
dlt1cy
Well, what happened?
Old Apr 4, 2006 | 04:54 PM
  #44
Quamen's Avatar
Quamen
Does unplugging the grey cable in the engine bay take car of the fuel cut while braking problem?
Old Apr 5, 2006 | 09:02 AM
  #45
Quamen's Avatar
Quamen
bump on the fuel cut problem
Old Apr 5, 2006 | 07:02 PM
  #46
dlt1cy's Avatar
dlt1cy
Tried Chebosto's method today. Worked like a charm. I have an 03 5at touring w/ TCS only. Observations:
Everything discussed is disabled,
Lights on dash stay on,
Speedo does not work,
Odometer does not work,
Brake lights do work,
Can smoke tires all day long while holding brake. (so no fuel cut)
I also noticed a huge difference in braking control. They were alot "touchier". The gray plug in actually more of computer plug, much like the ecu plugs. It plugs left to right (not up and down) There is a black "swing latch" over it. To remove, push in on the gray notches and lift the black over them. (there are 2 notches, one at bottom of gray plug and and one at the top of the gray plug to keep black "swing latch" from loosening) It takes about 10 sec once the cover conceling that corner of the engine bay is removed.
Hope this helps. This should also be posted in the drag racing section for those who need to heat their tires.
Old Apr 6, 2006 | 02:15 AM
  #47
punish_her's Avatar
punish_her
awsome info.
Old Apr 6, 2006 | 05:07 AM
  #48
Quamen's Avatar
Quamen
I know that this would take care of the fuel cut for the AT's but what about the MT's?
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
