What is top speed in each gear?
Old Jun 28, 2005 | 01:17 PM
dreamspeed's Avatar
dreamspeed
Default What is top speed in each gear?
Was wondering if anyone knows the top speed you can go in each gear before hitting redline? Thanks
Old Jun 28, 2005 | 05:27 PM
EdgeOfSanity's Avatar
EdgeOfSanity
its the speed of search
Old Jun 28, 2005 | 05:38 PM
sentry65's Avatar
sentry65
the burninator
doesn't the manual say?
at least for the first 3 gears...
Old Jun 28, 2005 | 08:53 PM
dreamspeed's Avatar
dreamspeed
i did browse through the manual but didn't see it, its probably in there though, and funny thing is i've actually been trying to figure out where the search button is
Old Jun 29, 2005 | 12:19 AM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
I believe it's 35, 60, 85, 110 is what i thought but i might be wrong i dunno after that though but those are the maximum allowed speed in each gear
Old Jun 29, 2005 | 01:50 AM
southern_info's Avatar
southern_info
I know for a fact 5th gear maxes out and hits the rev-limiter at 146mph.
Old Jun 29, 2005 | 05:40 AM
dwnshift's Avatar
dwnshift
Depends on what final drive you have and RPM limit.
Old Jun 29, 2005 | 08:35 AM
DomZ's Avatar
DomZ
I have a 5AT car, my 3rd gear tops out at about 104-105 and my 4th gear at redline shifts at about 136, so if I was manually shifting I might be able to get 137-138 out of it
Old Jun 29, 2005 | 05:46 PM
thawk408's Avatar
thawk408
My 4th maxes out at 120.
Old Jun 30, 2005 | 06:30 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Stock at fuel cut 6MT
1st=36
2nd=61
3rd=88
4th=112
5th=142
6th=186 ?IIRC
With 7100 ECU
40
65
95
120
150
Old Jul 5, 2005 | 11:10 PM
dreamspeed's Avatar
dreamspeed
cool thanks
Old Jul 6, 2005 | 03:55 AM
dwnshift's Avatar
dwnshift
If you search this forum...I made a complete gear chart for both the 3.9 and the 3.5.
Old Jul 7, 2005 | 06:34 AM
frenzy757's Avatar
frenzy757
speaking of flashed ECU's can i just go to a dealer and ask for the reflashed ECU?
Old Jul 7, 2005 | 08:44 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Hell no. You either have to send it Technosquare, or go to Altered Atmosphere in Maryland and get it done....
Old Mar 19, 2023 | 05:53 PM
Alecte's Avatar
Alecte
5th on my 08z tops at 158-159
Old Mar 20, 2023 | 01:44 AM
travlee's Avatar
travlee
Master
18 year old dead thread, and bullshiit on your top speed
Old Mar 20, 2023 | 04:26 AM
Alecte's Avatar
Alecte
a hole alert. here’s video proof so you can stuff your ego down your throat. Stock base 6 speed. The hrs didnt come with a governor. Maybe if you actually used this forum instead of moaning youd know that.
Old Mar 20, 2023 | 04:28 AM
travlee's Avatar
travlee
Master
https://youtu.be/sOtjNMS0pZk
yep confirmed **** waffle... public street, shame you didnt slam into a pole
Old Mar 20, 2023 | 07:38 AM
i8acobra's Avatar
i8acobra
You know "indicated" isn't "actual", right? Most cars are off by about 10% or more at that speed. You were probably about 140. Look at the GPS speed on your phone for an accurate number.
Old Mar 20, 2023 | 08:14 AM
iideadeyeii's Avatar
iideadeyeii
3.538 Rear end
26.3" Tire Height assuming 265/35r19 (245/45/18 is taller)
7500RPM
1.0 5th gear ratio = 165mph
https://spicerparts.com/calculators/...rpm-calculator
