Synthetic oil
Old Jul 14, 2005 | 05:40 PM
SmO69's Avatar
SmO69
Old Nov 28, 2005 | 04:40 PM
NISMOFO's Avatar
NISMOFO
Originally Posted by BriGuyMax
Every car I've ever put Mobil 1 in slowly consumes it. I now run AMSOIL and have not had any oil consumption issues at all. All I hear on here is how people consume Mobil 1...I think it's Mobil 1 that is too thin...not synthetic in general. Since a vast majority of people that run synthetic run mobil 1 (probably beacause of it's availability), I would say that's where this theory is coming from.
Do you run the AMO AMSOIL as shown in the link below correct?
AMO AMSOIL 10W-40
I think I'm about to order some of this.
Old Nov 28, 2005 | 09:47 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
AMO AMSOIL 10W-40
No...I run the AMSOil ASL 5w-30
https://www.amsoil.com/storefront/Se...x?CategoryID=7
Old Nov 28, 2005 | 09:55 PM
MySunset350Z's Avatar
MySunset350Z
Originally Posted by sp1kez
85 octane?? I've never seen a gas station that sold that low of an octane.
its labeled "economy" grade. not too many gas stations have it. i dont think its a good idea for the z. you can foul your plugs and clog your injectors. it'll cost you more $$$ in the long run.
Old Nov 29, 2005 | 03:47 AM
PoWeRtRiP's Avatar
PoWeRtRiP
amsoil is actually good for the life of the engine. with amsoil you should never need to change the oil again, just the filter. there have been numerous tests showing that even after thousands of miles the oil is still in great condition. not that im recommending you to never change your oil, but amsoil is the $hit
Old Nov 29, 2005 | 04:51 AM
NISMOFO's Avatar
NISMOFO
Thanks. I went with the 10W-40 AMSOIL. I went with that weight because that's what APS recommends.
Old Nov 29, 2005 | 05:29 AM
blasian's Avatar
blasian
Great quote in the sig
Old Nov 29, 2005 | 09:33 AM
mrtomcat's Avatar
mrtomcat
I'm running AMSOil 10w-40 and AMSOil Filter and AMSOil for the Dif and Tranny...
I love the results
Old Nov 29, 2005 | 10:12 AM
jjellyneck's Avatar
jjellyneck
I've been running Amsoil in my vehicles for quite a few years. Great stuff. My G35 coupe has 17K miles and does not burn a drop. I run 5W30 in the summer and 0W30 in the cold months.
Old Nov 29, 2005 | 02:20 PM
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by SmO69
asking questions like "do you have a radiator for the power steering?".
They do have power steering oil coolers you know.
I know what you mean. Headlight fluid is one of them.
Old Nov 29, 2005 | 05:21 PM
JERZ33's Avatar
JERZ33
  • Radiator/Thermostat/Water Pump/Radiator Hoses for a 79 VW Bettle
  • Anything for a 1983 Corvette
  • Alternator Fluid
  • Brake Light Fluid
  • Bucket of Steam
  • Front brake light bulb for a ....
I work at Pep Boys... we love the new kids, and we get bored on Wednesdays...
Old Nov 30, 2005 | 06:05 PM
nate_johnson17's Avatar
nate_johnson17
Mobil 1 5W-30 is not any thinner than any other 5W-30 oil, that is once the oil heats up. All synthetic oils start out thin to reduce wear and tear on the motor. And when you are going from standard oil to synthetic it is a good idea to run a blend for one oil change. The reason for this is to help the gaskets expand to stop any leaks that may occur with the use of a full synthetic (synthetic oil is famous for causing engine leaks). At least this is what I learned in training when I was managing a VIOC center. That job sucked BTW!
Old Dec 1, 2005 | 03:16 AM
atlsupdawg#2's Avatar
atlsupdawg#2
I think I'll be switching from Mobile1 to Amsoil. From all the reviews here it seems that it's the "Zaino" of engine oils.. It also seems as though Amsoil is a different blend than Mobile1, so when I switch would it be wise to flush the motor with engine flush??
Old Dec 1, 2005 | 03:27 AM
G35audioman's Avatar
G35audioman
Am I the only one on here running Amsoil 0w30?
I love that oil. It really holds up well and keeps the engine performing like it should. An oil analysis a while back confirmed this as well.
Old Dec 1, 2005 | 05:55 AM
jjellyneck's Avatar
jjellyneck
I use it in my G coupe in the winter months and in the summer as well if I happen to have it in my garage. If not, then I use the Amsoil 5W30 for summer months. The 0W30 is excellent stuff, with a superb molecular structure for proper lube.
Old Dec 1, 2005 | 09:27 AM
MySunset350Z
blackstones laboratories are great for oil analysis. i've been sending them samples with every oil change. its nice to know whats going on inside your engine without having to dump a ton of $$$ into it.
Old Dec 1, 2005 | 01:13 PM
JERZ33's Avatar
JERZ33
Got a link or something?
Old Dec 1, 2005 | 01:31 PM
  #38
MIAPLAYA's Avatar
MIAPLAYA
http://www.blackstone-labs.com/ I just sent my first sample of Turbonetics TS-1 in for analysis
Old Dec 1, 2005 | 06:37 PM
  #39
mrtomcat's Avatar
mrtomcat
I just ordered my kit. This is definetely worth while trying out
Old Dec 1, 2005 | 07:14 PM
  #40
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I've been using blackstone reports for years....they are fantastic. My Z's first report after the turbos is coming soon!
