Revs bouncing at idle.... What does this mean???
Old Sep 20, 2005 | 08:22 AM
Th3Cleaner's Avatar
Th3Cleaner
Originally Posted by Ep3
this sounds different then everyone else, if it only happened after you installed the plenum you probably have a leak somewhere. if i were you i would go around and make sure all the bolts are tightened to speck and everything is flush.
I did my plenum by using that Glad Press'NSeal
http://www.glad.com/pressnseal/faq.html
I just layed it over the plenum and "pressed it on" untill it was sealed, started the car up, it sucked in the areas that needed to be tight, I did and drove the car and re did it until the press'n seal no longer sucked in.
Old Sep 20, 2005 | 08:29 AM
seanlaw's Avatar
seanlaw
after i installed my test pipes the idle increased and smoothed and does not bounce anymore
Ep3's Avatar
Ep3
haha good idea
Old Sep 20, 2005 | 09:50 AM
350Zenophile's Avatar
350Zenophile
classic!
Old Sep 22, 2005 | 10:19 AM
johnk024's Avatar
johnk024
I had that happen to me and it turned pout that the filter on my CAI was dirty and that was causing the bouncing idle
Darkspy
Sep 7, 2015 09:09 PM
