Best NA Sound/Grind friendly Clutch+Flywheel
Old Jul 18, 2005 | 01:13 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Default Best NA Sound/Grind friendly Clutch+Flywheel
I just blew my clutch out and am looking for a new clutch and flywheel combo.
I want something with significant performance gains minimal gring under 2500 RPM. Can you guys please make a suggestion.
Also the dealer will hook up a great install price as long as they are "matching" and not "in pieces." Can someone please explain how a combo would NOT BE matching?
Also is $550.00 a good price for dealer install?
Old Jul 18, 2005 | 01:21 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
If sound is a concern, stick to OE as far as flywheel goes. Even mildly lighter flywheels chatter noticeably at idle as well as up to 2500rpm.
Old Jul 18, 2005 | 01:26 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
From what I've been reading, I think the JWT Flywheel + Clutch combo would fit your search criteria. Although the Flywheel does have some slight chatter at lower rpms, it's not that bad. Then again, this is very subjective so I'd suggest asking a local member if you can listen to theirs.
EnthuZiast's Avatar
EnthuZiast
So the Tilton Flywheel wouldnt do it for me huh?
Any suggestions on a good "wear and tear" clutch.
Old Jul 18, 2005 | 07:02 PM
imoz's Avatar
imoz
Jason from Performance Nissan posted a bunch of videos on another 350Z oriented message board of his car with the Tilton setup on the street and the drag strip. It didn't sound bad at all to me and the way the car revs is simply amazing.
Old Jul 18, 2005 | 09:04 PM
joust75's Avatar
joust75
My freaking stock flywheel chatters anyway so I will be getting the JWT
Old Jul 18, 2005 | 09:35 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Very true ..but after the JWT, I have to push in the clutch to be able to hear myself order a combo at the drive-thru.
Old Jul 18, 2005 | 11:12 PM
EnthuZiast's Avatar
EnthuZiast
Just ordered the JWT cltch/flywheel. I will post my impressions if you guys like.
Old Jul 19, 2005 | 06:07 AM
g356gear's Avatar
g356gear
I had the JWT fly/clutch installed yesterday. Honestly I don't know what you guys are talking about with this chatter. Mine sounds identical to stock. The clutch pedal engagement is closer to the floor and is a little stiffer, but other than that I can't hear any difference. RPM's do come up slightly faster. Maybe the sound from my plenum is drowning it out.
Old Jul 19, 2005 | 06:29 AM
rednezz's Avatar
rednezz
The JUN flywheel is also very quite with the oem clutch. With the stock clutch it sounds just a hair louder than stock.
Old Jul 19, 2005 | 07:57 AM
Tantrum Z33's Avatar
Tantrum Z33
I thought the same thing too when I first had the JWT flywheel installed. Give the flywheel a few days and you will start to notice the chatter.
Old Jul 19, 2005 | 07:59 AM
Diesel350's Avatar
Diesel350
Sentry stated that if you bump the idle it will get rid of that unwanted noise.
Old Jul 19, 2005 | 08:06 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Geez my JWT flywheel is very quiet. Almost no chatter whatsoever and I have had it for a bit now. It is a great mod IMO. Almost wish it had a little more chatter
How'd you burn out your clutch Tom????
Old Jul 19, 2005 | 09:12 AM
Jaki's Avatar
Jaki
Are you sure the installation and adjustment is good?
I have the JWT combo as well, and like most other people the noise is minimal and the exhaust (even when I had the stock exhaust) makes more noise and makes the flywheel chatter unoticeable.
Also, if you haven't done already, I would suggest to bump your idle a bit, that might help you a little. My "noise" was the same before and after the idle bump.
I think by "matching" they mean if you buy a flywheel and clutch from different brands, then they might have to adjust something to make it work properly. $550 is kind of a mid-high price for a flywheel and clutch installation. I'm sure you can find a better price than that.
+1 on everything. I had mine for about 4 months now, and I rarely ever hear anything.
Old Jul 19, 2005 | 09:35 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
yeah my clutch pedal engagement is very low now and very short with the JWT.
Also, I paid $290 to get it all installed with a short throw shifter.
Old Jul 19, 2005 | 07:01 PM
g356gear's Avatar
g356gear
I noticed this as well....clutch engagement is very low. My tech adjusted it a little so it is more off the floor. I had the idle bumped to 875 already for some JWT cams.....maybe that is why its not as loud.
Old Jul 22, 2005 | 12:52 PM
EnthuZiast's Avatar
EnthuZiast
I will drive the car for the first time with the JWT and I will let you guys no.
I was very suprised at how quickly my stocker went from bad to worse. After 4 days of driving on the slipping clutch it blew out all together.
My car is completely immobile and I had to have it towed to a performance shop.
Install is $350.00 and I think thats fair.
Doesn't sound like you gusy felt much of a performance gain
I would think that a 14lb. flywheel would change the revvs more than just mildly.
Old Jul 22, 2005 | 01:01 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
I could feel the difference for sure. my car feels much faster. Its a great mod. You cant help but like it.
Old Jul 23, 2005 | 12:21 PM
EnthuZiast's Avatar
EnthuZiast
I have it on but Im afraid to get on it right now. Im thinking there has to be some sort of "break in" period. When I revv a lil in neutral I can tell the RPMS decelerate quicker for sure.
Old Jul 23, 2005 | 12:39 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
a few hundred miles is all. as long as you dont beat on it should be fine
May 30, 2017 03:28 PM
SharX59
Sep 27, 2015 09:23 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
