Eibach springs ARE OUT!?
Old Dec 11, 2002 | 03:51 AM
Gin262's Avatar
Gin262
Originally posted by VQracer
Ground-Controls have been out for a while too, but I never posted cause I think they are ___!
Ground-Control calls them coilovers but they are just springs made for looks. True coilovers are designed with the shocks/strut in mind along with other suspension components. Ground-Controls are just adjustable springs that apeal to people who are just going for looks. The ride is horrible. And like Cheston said, they sag over time.
Yeah, Ground-Controls suck... IF you use the stock shock! many amateur race teams use Ground Controls with Koni or better shocks... why? Easy adjustment. And not just ride-height. If you call Ground Control and order from them you can specify the spring-rate you want. Don't like the rate you picked??... get new springs for 50 a pop. Try that with JIC or Tein.
Oh yeah, Ground Control uses Eibach springs... I guess all Eibach's sag.
Having said that... Getting a packaged deal (JIC, Tein, etc.) is probably better for the average (street) driver. But it'll usually be much more expensive.
Blake
EDIT: Found this on Ground-Controls website:
"Springs: All our ride height adjustable kits feature Eibach Springs. these high quality springs offer a lifetime warranty against any defects."
I would assume sagging would be a defect...
Old Dec 11, 2002 | 01:33 PM
J Ritt's Avatar
J Ritt
So I haven't seen one mention of the actual change in spring rate from stock to the eibachs...why in the world would you consider buying springs (or any setup for that matter) if you don't know how these springs will affect handling? Is it just so the car sits lower? Doesn't it matter if you bounce down the highway on the springs without compressing the shocks?
cabalisticfire, thank you for the sane reply.
Old Dec 11, 2002 | 02:48 PM
Fyrestrike's Avatar
Fyrestrike
In my experience with Eibachs they all sag. For the Grand Prix they had to release a revised set because the fronts were a full 1.5" higher then the back. Even with the revised springs the drop is still uneven.
Old Dec 11, 2002 | 03:55 PM
wadd3456's Avatar
wadd3456
Interesting. My only complaint with Eibachs is that they DONT always drop as MUCH as they say they do. This would be the opposite of a sag issue.
Intrax on the other hand keeps dropping and dropping and dropping.....
Old Dec 11, 2002 | 06:37 PM
Thunderbolt's Avatar
Thunderbolt
Charter Member #88
Originally posted by Gin262 h yeah, Ground Control uses Eibach springs... I guess all Eibach's sag.
I would assume sagging would be a defect... [/B]
All springs will sag/fatigue to some amount. Some more than others. This is why it is important we can set the camber on our cars. Sagging springs will cause the insides of the tires to wear.
Old Dec 12, 2002 | 03:58 PM
jreiter's Avatar
jreiter
If you have adjustable-height suspension, just raise it up a bit to compensate for the sagging springs. Generally, a spring will only sag a certain amount during an initial break-in period. After that, it's probably safe to adjust the height (if you have that ability) and be done with it.
If you don't have threaded coilovers, some shocks (such as Bilsteins) have slotted mounts for the spring perches, allowing you to make limited adjustments to height. Not as fine-tunable as threaded coilovers, but still useable if your springs sag too much.
Old Dec 13, 2002 | 10:49 AM
Gin262's Avatar
Gin262
True... I suppose I meant excessive sagging would (should?) be a defect.
Blake
Old Dec 16, 2002 | 11:04 AM
Driven's Avatar
Driven
Response regarding one of the above posts about putting additional weight in the trunk in order to get a "feel" of what to expect with Eibach springs. I'm the first to admit I don't have experience in this area, but the physics seem backwards on the example. If I put more weight in my car now and the ride smooths out....how in the hell does that translate into the same type of ride with the same shocks and stiffer springs??? When I went to stiffer springs in a Wrangler I had...and kept the shocks the same, I had to put the weight in after the change to get the same kind of ride as before. This is consistant with logic for me: stiffer springs with more weight = softer springs with lighter weight.
Old Dec 16, 2002 | 12:21 PM
z461's Avatar
z461
The logic was that if you compressed the stock springs with more weight in the rear, then they acted like higher rate springs with less compression. When more weight was put in the rear of my car w/ stock springs/shocks, the car rode better. Therefore if my logic is correct (it could be wrong) I think that stiffer/shorter springs would make the ride better or at least reduce the amount of porpoising @ certain speeds.
Old Dec 16, 2002 | 02:39 PM
wadd3456's Avatar
wadd3456
It says yours are on ORDER? PLease PM me about that.
Old Dec 16, 2002 | 07:18 PM
Driven's Avatar
Driven
I kind of understand what you are saying...but don't agree with the analogy. I don't experience any "porpoising" in my current stock ride...it is however very "bumpy" like I would expect from a stiff performance suspension. When you use the word porpoising I think of how any car would ride when it's shocks are shot ie. you push down hard on the bumper and let go and the car bounces numerous times to come back to static condition. If this is what you are experiencing, then I agree...shorter/stiffer springs will reduce this characteristic...but will not ride at all like your stock suspension under load. IMO that simulation is similar to making a Corvette into a Cadillac. The heavier weight in my eyes would promoat the "floating" feeling over bumps.....anyway, that's my take. Doesn't much matter...buy em and tell us your opinion afterward.
Old Dec 16, 2002 | 10:37 PM
z461's Avatar
z461
Oh ok... i see what you're saying, makes sense if it was a lot of weight, but I merely put about 40-50 lbs of stuff in the trunk I believe. So it's NOT like I added 2-3 hundred lbs of stuff to make the car heavier and basically ride over the bumps... Also, porpoising if you search is a condition in the Z where the car's rear will bounce up and down over certain roads excessively at speeds between 45-75mph... This was determined by several people who analyzed the suspension (and they could be wrong) to be caused by the shocks being valved too heavily for the stock spring rates.
Old Dec 17, 2002 | 07:03 AM
Driven's Avatar
Driven
Everyone is going to blast me on this....I can hear it now. But.....you mean there is a solution to my not being able to drink coffee in my Z on the way to work? (banter in the background, "you shouldn't have bought a Z if you wanted to drink coffee....it's a sports car!")
Honestly if what you are talking about may provide a better street ride without losing and maybe improving track performance....sign me up!
Old Dec 18, 2002 | 03:55 AM
MR RIZK's Avatar
MR RIZK
FYI
H&R have brought out a set of springs for the 350z. If you want something that sits lower that the Eibachs then the H&R's might be for you.
Eibachs
Front 0.8"
Rear 1.2"
H&R
Front 1.5"
Rear 1.5"
http://www.hrsprings.com
Old Dec 18, 2002 | 06:26 AM
Driven's Avatar
Driven
Someone buy them, install them, and report back to us....please.
Old Dec 18, 2002 | 08:12 AM
wadd3456's Avatar
wadd3456
Man that would look nice with some 19s tucked up there.
Old Dec 20, 2002 | 07:46 AM
datspeed77's Avatar
datspeed77
Originally posted by dczoner
I would tend to think that Eibach has had a few months to play around with the G35/FM platform, and then figured out how to toss that the Z's direction. Not much to springs, really, once they've got the tools it just takes a little trial and error to get the right mix.
Interesting that it gives a .8" front and 1.2" rear drop (if I'm reading this right). . . Seems awful low for just a spring set, and also I wonder if the .4" difference is noticable.
Also FYI, they do have a G35 kit as well, 1.1" drop all around.
You guys might want to wait for the H&R springs. Supposedly it should lower the car by 1.5" all the way around. At least that's what my dealer price sheet lists. But, they're not out yet.
Old Dec 20, 2002 | 10:51 AM
  #38
johnlotusboy's Avatar
johnlotusboy
H&R springs are not out yet, the prototypes will be arriving in the first week of Jan. and I will be testing them on my car for them. Today (20 Dec.) we are doing the first of the testing on a stock car at 2pm PST at H&R to verify original #'s on the stock suspension.
I will post pictures and info this evening after I get home.
H&R is in my home town of Bellingham, WA. Nice to have people like that in my home town.
Old Dec 20, 2002 | 01:28 PM
  #39
wadd3456's Avatar
wadd3456
Dont go out and measure/test it the second you drop it. It takes sometimes up to 3 days for a car to fully lower. I bet you 20bux it doesnt drop more then 1/2" when you first do it. Then tomorrow you will walk out and look at it and say "wtf!"
Also, what are you doing about your camber?!
