Crank Pulley Suppliers
Old Aug 10, 2005 | 12:24 AM
WestCoastRiot's Avatar
WestCoastRiot
Default Crank Pulley Suppliers
I would like to know who they all are and maybe a web address to check them out would be great, What is the most common here on these boards and in the general public?
Old Aug 10, 2005 | 12:30 AM
Z BOY's Avatar
Z BOY
unorthodox racing has an underdrive.
kjr has a lightwt non-underdrive.
Old Aug 10, 2005 | 03:50 AM
DavesZ#3's Avatar
DavesZ#3
www.kjrperformance.com
Old Aug 10, 2005 | 05:53 AM
mcduck's Avatar
mcduck
Yep... the KJR piece rocks! We saw a few at ZDayZ (and gave one away as a prize!). They are very well crafted and very, very light!!!
Old Aug 12, 2005 | 01:53 PM
JonathanAboona's Avatar
JonathanAboona
our latest batch supply is running low.... were out of billet again but have black in stock
more coming from the manufacture soon....
Old Aug 12, 2005 | 03:48 PM
WestCoastRiot
Which is better?
Which is safer?
Old Aug 12, 2005 | 09:25 PM
gatti-man's Avatar
gatti-man
Originally Posted by WestCoastRiot
Which is better?
Which is safer?
KJR is safer bc it isnt underdrive just a lighter version of the stock but how do you install it? Also what are the typical gains?
Old Aug 12, 2005 | 10:00 PM
WestCoastRiot
Im sure the install is the same for any crank pulley. I would think the udnerdriven pulley will show more gains because its mroe then jst a light weight options.
I remember on the BMWs i use to run the light weigh crank pully would gian you about 3-5whp as the udnerdrive would gian you 5-9whp
Both are safe. As long as you dont underdrive the crnak and run a lightweight flywheel. Its all good from there
Old Aug 12, 2005 | 10:55 PM
AvengerZ's Avatar
AvengerZ
why not run a underdrive pulley with light weight flywheel?
Old Aug 12, 2005 | 11:39 PM
WestCoastRiot
A lightweight flywheel throws off the harmonic balances and a crank pulley throws of the harmonic balances. the two together throw the harmonic balances off so far that serious damage WILL occur to the engine. I am trying to locate my harmonic balance tech sheet. will post it a.s.a.p
Old Aug 13, 2005 | 12:09 AM
AvengerZ's Avatar
AvengerZ
thank you ^_^
Old Aug 13, 2005 | 04:39 AM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Your claim is NOT what I have heard. Back it up with data/sources.
Old Aug 13, 2005 | 06:28 AM
nuff's Avatar
nuff
The part about flywheel is ********, our stock flywheel is a 2pice design and it doesn't have any harmonic balances. I'm not sure where you have made that up. Also crank and flywheel are balanced independently, why do you think that nismo sells their own lightweight flywheel.
Old Aug 13, 2005 | 11:06 AM
HockeyZ39's Avatar
HockeyZ39
So it is safe to get both!? Cuz the light wieght flywheel and crank pully where the next two things on my list!
Old Aug 13, 2005 | 02:55 PM
JonathanAboona
www.kjrperformance.com has a dyno before and after with the KJR on it. You can expect approximatley 8 hp to the wheels with this pulley. Stock pulley weight is 6.4 lbs and the KJR is 2.02 lbs
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
