JUN Flywheel and CMIII Clutch are in! Kudos to CPRacing for a job well done!
Okay... I've been sitting on a clutch and flywheel upgrade for almost a year now. There have been numerous excuses and delays, but this week the deed was finally done and the parts are in the car.
First, I'd like to thank CPRacing for doing an awesome job on this for me. Normally, my car goes to another shop in town (CHL Motorsports) for mechanical work and I use CPRacing for tuning. Since CHL is essentially a one-man shop, it makes it difficult to pull off any tranny job. So, CPRacing was tapped for the clutch & flywheel. At this point, I'm relieved to know I have two excellent shops in town to turn to! :thumbsup:
The Parts
JUN Flywheel - I decided I wanted a lighter flywheel, but not one that would compromise around town driveability much. So, the 8lb Tilton was out of the question. I elected to go with the 14lb JUN. Another contender was the JWT, but I liked the design of the JUN much better and the fact that it is a one piece part instead of a two-piece part like the JWT.
Clutch Masters FX300 Clutch - This unit had 3 big things going for it. #1 - it was more than adequate for the level of power I'm pushing. If I went with upgraded internals and more power, I would have jumped up to their higher level offerings. As it is, the FX300 will meet my needs.
#2 - More than double the clamping power of the stock clutch.
#3 - Sharif just happened to have one on hand that he decided not to use in his car and I was able to pick it for significantly less than ordering on line! :biggrin:
The Install
As mentioned, CPRacing did this for me. I've only had the car back for 24 hours, but every indication is they did an awesome job. The car was dropped off on my way into work yesterday (Matt was even kind enough to drive me from CPRacing to my job. Thanks, Matt!) and was in the parking lot waiting on my when I got back to CPRacing at 4pm. Reasonable price for the job and it includes a return visit later to get a new dyno run to tweak my tune (Eric suggested waiting until the new clutch had some use before re-dynoing or it would have been done yesterday). Only minor complaint I have is the shift gates feel a little different now for 5th & 6th. Nothing I cannot adjust to, but noticeably different 4-5 and 5-6 movement. Eric and I could not reason out why this would be since the shifter mount should not have been affected by a clutch/flywheel swap.
The Results
All I can say is .... WOW! :OMG:
Okay, I can say a little more.... my car has been transformed. You'd think after full exhaust, cams, Vortech, and other upgrades like suspension, etc., it would be hard to "WOW" me. But, this upgrade makes a very noticeable difference in the feel and performance of the car.
The throttle is so much more responsive. A simple blip of the throttle winds the motor so much higher and quicker now. The revs come up faster... enough faster that there is no mistaking there is a huge benefit to the weight difference of the JUN. In fact, 1st and 2nd wind so quickly, I've had to adjust my shifting technique to avoid hitting redline. Literally, 4000rpm to 6600rpm is a blur.
The clutch took a little more getting used to. My previous stock clutch let out very high in the peddle range of motion. The CMIII lets out quickly at the bottom of the peddle. I'd say total play from starting to grab to full grab is less than 1/2" of motion. It's almost like an on/off switch. Still, it's not fussy... I could ease into gear just enough so city driving is not a task and with a quick shift it obvious how much more rapidly the clutch grabs. So far, no stalls.
Rev matching is no more difficult with this clutch, IMO, than it is with the stock clutch. In fact, I found the downshifts to be much easier as the motor revs more freely to the higher rpm of the lower gear.
Flywheel noise? I have barely any. Sharif had suggested getting my flywheel balanced before install to help reduce any low rpm noise, but I never got around to it. With it now in the car, I get almost none of the 'flywheel noise' I've heard others describe with other flywheels. At an idle, before the car has warmed up, there is a little bit of rattle. After the car is warm and any time above 1000 revs, the flywheel actually makes less noise than my old stock unit.
Overall, I'm very pleased with this upgrade and hate that I waited so long to put it in. IMO, the lightweight flywheel upgrades is one of the few upgrades I've done that individually had an immediate, huge, positive improvement to the cars performance and feel (the only other two things I can say fall into this category are my Crawford Headers and the Vortech SC).
For those on a budget, I think this is probably the single, best upgrade you can make. The car **FEELS** some much more responsive now, that as soon as the streets dried yesterday, I hopped back in the Z and basically went joyriding for several hours. Like when I first bought the car, I literally did not want to get out of it because it is so much fun to drive.
The Parts
The Install
The Results
What is the holding power of that clutch. I'm looking at getting one and I am already dead set on the Jun flywheel. Just looking for a decent clutch at a decent price. But it needs to hold me over at least until next summer when I put in the built motor and ATS unit...
My baby has been at CPRacing for almost two weeks now and I love hearing that people are very satisfied with this shop (not that I'm not already, but it's still good to see
After all the N/A mods I did to my car, when I switched to a heavier flywheel (went away from the tilton), it felt like someone had robbed all of my power gains. Lightweight flywheel / clutches are some of the best mods you can do on this car (i'm getting the ATS installed right now
)After all the N/A mods I did to my car, when I switched to a heavier flywheel (went away from the tilton), it felt like someone had robbed all of my power gains. Lightweight flywheel / clutches are some of the best mods you can do on this car (i'm getting the ATS installed right now
I loved my JUN flywheel..... but due to my s-tune engine cannot idle properly with this flywheel, I gotta swapped it out for a heavier nismo piece.... I really miss the JUN flywheel.... simply love it!
Enjoy it mate!
richie
Enjoy it mate!
richie
i was in market for flywheel, clutch and header.
do you mind if i ask you individual components price and intallation cost?
if you don't want to post it, please pm me. thank you.
The last trackday (16 July) in Monza circuit (35° °C temperature) was fatal for my stock clutch and flywheel ; i replaced , by Performancenissanparts , with the Nismo Clutch (Disc & Cover) and JWT flywheel.
The car runs very well , but the transmission noise under 2100 rpm , in particular in 4 - 5 - 6 (gear) , is intrusive....
It's normal with this setup ????
Any suggestions...??
Thanks for your reply...
Originally Posted by Phatmitzu
Noice!
How much was the JUN flywheel?
JUN flywheel = $450 (approx)
CM FX300 Clutch = $500 (approx)
Crawford Headers = $1200
Rather than list install prices, I'll put times since labor rates can vary.
Headers = 6-9 hours
Clutch & Flywheel = 3-4 hours
Glad to hear a good review of the JUN flywheel, I'm thinking about this as a performance upgrade to hold over until I can do some more serious engine work (read: until I get out of college and get a good paying job). Is the throttle response worth it?
BTW, where is CPRacing in Charlotte? Are they closer to Mooresville b/c I have had to drive there a couple times and would feel much better about using that shop than one in NoVA. There really aren't many reputable shops in southwestern VA.
Do you know if the JUN flywheel would work with Nismo clutch? I know that the JWT one will.
I have the Nismo/Nismo combo right now, but I think I may want my flywheel to be even lighter.
