has anyone thought about putting a transmission cooler in this location?
for many of us with aftermarket exhausts, there's this big blank spot right in front of the rear muffler that the OEM muffler partly covers for aerodynamic reasons.
I'm wondering if a transmission cooler could be rigged up to be mounted there facing down?
would it work?
stupid idea?
I'm thinking it'd help with aerodynamics, let you use one and an intercooler for a turbo kit, and it adds the weight to the rear instead of the front
would it work?
stupid idea?
would it work?
stupid idea?
would it work?
stupid idea?
I think a diff cooler would be better to have there than a tranny cooler. I'm assuming this is for an AT? I wonder if it would really have enough air flow to work well enough to keep tranny temps down at the track without some actual ducting to help airflow into it. If you could fabricate some kind of NACA duct under there with an otherwise flat belly pan extending from the diff to the rear bumber cover, that would be really trick and highly effective.
Will
Will
The 350EVO race car has a diff cooler there. I saw it during after the MidOhio Grand Am race this year. Then again, that is a racing car not too subject to crap in the road.
If you do put one in, consider a Mocal oil pump. Google it and you will find plenty of info.
Tochigi_236
09-27-2015 03:40 PM
