Anyone had a problem with car starting after removing J&S >>
Old Sep 16, 2005 | 08:40 AM
was wesman's Avatar
was wesman
Default Anyone had a problem with car starting after removing J&S >>
I have de-modded my car and now it doesn't want to start.
I had the J&S installed and since uninstalling it seems as if the car isn't getting fuel, it just cranks and makes no real effort to start. I think it may be a problem with the anti-theft system. However, I want to cover all my bases before bringing it to the dealer to see if they can reflash it.
Has anyone had any issues with starting after pulling the J&S ?
--wes
Old Sep 16, 2005 | 02:06 PM
Badmonkey's Avatar
Badmonkey
The J&S intercepts the coil signals. The wires are cut and spliced into a waste spark adapter. I have had mine in and out several times with no problems. I would check and make sure the wires are put back together correctly. If the wires are correct, check the ignition fuse under the hood next to the battery, on the right. I think it is on the top right.
lolwatbro
Oct 9, 2021 04:58 AM
pslamp32
Feb 8, 2017 09:07 AM
OdesiTT
Sep 30, 2015 10:47 AM
PureR3d
Sep 10, 2015 06:23 PM
