Apperantly a LightWeight Pulley is bad for your car?
Old Sep 30, 2005 | 04:02 PM
  #41
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by Nano
double mass heavy *** flywheel was for comfort only. (should see the flywheels on some higher end sports cars...)
I didnt know flywheel was for comfort, its just funny how you said.
Why would engineers design comfort when engine block, crankshaft, bearing unidirectional loading is undesirable and can lead to reliability issues?
Comfort comes in when designing the engine mounts, how to damp the engine vibrations transferring into the chassis and not when designing the flywheel.
Old Sep 30, 2005 | 04:11 PM
  #42
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Heavy flywheels are used for smoothness and very nice engagement of the engine power to the transmission. But becuase they have a lot of mass to them, they result in more drivetrain power losses, and a less responsive motor.
I know your question was rhetorical, but I thought I would answer it anyways.
What type of engineer are you, BTW?
Old Sep 30, 2005 | 04:15 PM
  #43
Sharif@Forged
Forged Performance
Originally Posted by spcemn_spiff
Nissan V6 is balanced internally? The external part that balances the crank loads is the flywheel. I dont know what your source is, may be you have more information than me. I know that crankshafts have balance weights for each con rod/piston assembly, I assume that is what you meant.
I think Z1 was saying that the CRANK pulley is balanced internally...not the engine.
Usually, OEM's will remove material from the forged crank, rather than adding to it. When we build motors, and rebalance the rotating assembly, we also remove material.
Old Sep 30, 2005 | 06:40 PM
  #44
Nano's Avatar
Nano
You know that The clutch and flywheel are the single most importan element of transmission operation. You can bet yo'r *** it's designed to be as comfortable and seamless as possible. The stock clutch/flywheel is designed with a maximum of comfort as a compromise. It is heavy to store a lot of kinetic energy to avoid having to rev to 5000rpm at every corner and stop, it has a dual mass construction to isolate torsional load spikes from the engine, etc...
I don't understand where reliability issues would come from?
911 has heavy dual mass flywheel (smooth and quiet, considerable drivetrain loss, slow responsivness)
911 gt3 has lightweight single mass flywheel (noisy, harsh, least drivetrain losses and maximum responsivness)
Old Sep 30, 2005 | 06:57 PM
  #45
spacemn_spiff
Lets no confuse the function of flywheel and pressure plate, which are independant of each other. Flywheel balances the unbalanced mass on the crankshaft, pressure plate mates with clutch to provide the right coefficient of friction or in layman's terms more friction. The two are packaged in a single unit for compactness.
911 and 911 GT3 I believe have different internals in the engine (crankshaft, con rod, pistons) hence has different unbalanced rotating mass on the crankshaft and thus the difference in the flywheel mass or design. From what I can recall GT3 engine had higher redline, higher compression ratio and higher hp/liter than 911 engine.
Old Sep 30, 2005 | 07:39 PM
  #46
Nano's Avatar
Nano
actually the difference was between the GT3 and the GT3 RS, both have the same exact engine... GT3 has standard dualmass flywheel, GT3 RS has singlemass lightweight flywheel.
The engine is an extremely free-revving unit that develops 381 bhp at 7300 revolutions per minute from a swept volume of 3.6 liters. The maximum engine speed is 8200 rpm and the specific output 105.8 bhp per liter. These values are also applicable to the current GT3 model....... This abundant power is transmitted via a close-ratio six-speed gearbox. Between the engine and the gearbox the RS has a single-mass flywheel with a lower rotating mass than the double-mass version.
let me guess... your car is bone stock?
Old Sep 30, 2005 | 08:40 PM
  #47
spacemn_spiff
Well, so there is only one way of designing things? At least not in my book. It may be possible to cleverly design a low mass flywheel by playing with mass distribution. I think the point I made was convieniently ignored. I dont feel the need to discuss this further.
Through this discussion I felt that you are saying that manufacturers have the habit of increasing the mass of the flywheel/pulley etc. for no reason althought it might be costing them more money because higher material costs to say the least and they have no reason or need to optimize it.
I dont know why this has to become personal and what it has to do with my Z being bone stock 3 months after I bought it. I thought we were discussing something here.
Old Sep 30, 2005 | 09:03 PM
  #48
Nano's Avatar
Nano
sorry, I was just kidding --> see smilie. Nothing personal, relax
I explained the reasons of a heavier flywheel and the dual mass issue. I explained how the flywheel scope is to store kinetic energy, I explained how everyday joe wouldn't enjoy a lightweight flywheel4... I don't think this as anything to do with costs, it's an issue of common sense.
as for manufacturing, For example: the stock pulley looks like it is cast and machined. I don't remember seeing any form of ballancing artefacts on it. It's heavy, rusted and looks like crap... I really doubt it's more ballanced or has better mass distribution or whatever than the UR pulley. (I also highly doubt it costs more to manifacture).
I don't quite get your point (I'm not ignoring it). I don't understand why a lightweight pulley or flywheel can't be ballanced?
Old Sep 30, 2005 | 09:38 PM
  #49
G352NV's Avatar
G352NV
Great topic, glad I found it!
Old Oct 1, 2005 | 06:51 AM
  #50
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why does a Z have a dual mass flywheel? As mentioned..comfort and ease of driveability for the masses.
Lot's of cars have similar flywheel designs. RX7's do..... but wait, they don't have pistons or cranks, the entire block weighs maybe 100 lbs and has a total of 6 moving parts inside...so why the need for such an elaborate flywheel?
Noise reduction, and ease of overall operation. As mentioned, as you reduce weight on the flywheel, you increase drivetrain noise and also require more driver input to "smoothly" drive the car.
Maybe you can design a lightweight flywheel that also behaves as quietly as a heavier one. To date, no such animal exists however. What manufacturers have realized is that there is a fine line with EVERY engine where too light of a flywheel, while making the engine ultra responsive, makes it noisy and not what most people (enthusiasts included, not just the masses), will live with. Imagine if the Z came with a Tilton from the factory?
Adam
Old Oct 1, 2005 | 09:55 AM
  #51
21112's Avatar
21112
Adam
I'd be as happy as a pig in shizzle.
bcoffee20
Nov 19, 2015 06:39 PM
Shane86
Sep 17, 2015 05:33 PM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
