Turbos and Linear Acceleration
Old Dec 23, 2002 | 02:09 PM
phreezee's Avatar
phreezee
Originally posted by Zaphod 350z
Phreezee, my point wasn't that ECU don't make a difference. I had an S4 before this. I tested every ECU under the sun and I know what an ecu can do. My point was that people here seem to think that you won't gain anything from bolt mods without the ecu being retuned and that simply isn't true. You can get MORE out of a mod if the ECU is programmed for more aggressive values, but it's not necessary to see a gain.
I'll agree with you on that... and you really seemed to know what you were talking about in your second post.... it's just that the thread was on turbos and not simple bolt on's like CAI.
Old Dec 23, 2002 | 02:20 PM
TJZ's Avatar
TJZ
true
Old Dec 23, 2002 | 02:23 PM
TJZ's Avatar
TJZ
Originally posted by integrate
Um...a supercharger will do just as well for power in the higher rpms.
sure, if they are running the same boost. What you said didn't pertain to my post at all.
Old Dec 23, 2002 | 04:20 PM
integrate's Avatar
integrate
We were obviously talking about the powerband given by either a Turbo or Supercharger pushing the same amount of boost.
Certainly sounded like you said superchargers weren't going to give you power in the higher RPMs. Also, running a certain amount of boost would overall depend on how much HP you want....so, you made it sound like if a turbo and supercharger are running the same amount of boost, the supercharger wouldn't give you power in the higher RPMs.
"Yes, the acceleration will be less linear. BUT, it's not like our car is all of a sudden turn into a honda civic. We already have pretty good power down low so it's not like we're going to be struggling. What really need help with most is our upper powerband and the turbo will be extremely helpful at this, not to mention the power in the already strong midrange of out power band.
Turbos
SC"
Old Dec 24, 2002 | 06:41 AM
jnifong's Avatar
jnifong
I've always thought superchargers were good at low RMPs and turbos were more suitable for higher RPMs. Wonder if you can slap BOTH on there and maybe NOS too without completely blowing the engine to pieces? haha. But I've always like the feel of turbo serge.
Old Dec 24, 2002 | 12:19 PM
TJZ's Avatar
TJZ
Nope, i believe you read my post incorrectly. I was responding to OrangeJulius' post and i was discussing the power curve a turbo'ed car. I didn't discuss SC's at all except for my little " SC" comment at the end.
Old Dec 24, 2002 | 09:49 PM
integrate's Avatar
integrate
Ok, so my post did pertain to what you said. You said turbos give good power up top, and I said superchargers do that as well.
Old Dec 26, 2002 | 02:35 PM
TJZ's Avatar
TJZ
whatever man, we were talking about turbos and power curves. You feel like talking about SC's. let's try to go even more off topic, it'll be fun.
Old Dec 26, 2002 | 06:01 PM
integrate's Avatar
integrate
Sorry you think that only Turbos will give you power the higher RPMs. You obviously don't know much about forced induction since you were saying how we needed power in the higher RPMs, then started to bash superchargers with your small illustration. Maybe I should list some dyno sheets were a certain turboed car and supercharged car has the same peak horsepower.
How about we play Mr. Obvious?
"sure, if they are running the same boost."
Dyno chart of Turbo and Supercharged S2000. Interesting, huh?
Old Dec 26, 2002 | 07:29 PM
Ohio350z's Avatar
Ohio350z
If my memory serves me right, Internet Abyss spoke to a nissan engineer and they think the Z is perfect for a supercharger because this type of forced air induction matches up best with the linear powerband of the z. I am going to wait and see what develops before I choose. I don't want to be a guinea pig.
Old Dec 26, 2002 | 07:38 PM
integrate's Avatar
integrate
Roots superchargers give you power instantly, but a centrifugal supercharger normally gives you power in the higher RPMs because a centrifugal supercharger is related to what RPMs your engine is at, therefore, more RPMs, more power...generally speaking. Also depends on the efficiency of the supercharger.
With a turbo, it depends on the housing size. If it's small, it'll spool up quickly, therefore, giving you quick power and a linear power curve. That is why a twin turbo setup would be great since two small turbos are spooling up quickly. A big turbo for a relativily smaller engine will give you a power curve that's very peaky, since it'll take the engine a bit to power up the turbines.
Old Dec 26, 2002 | 10:11 PM
TJZ's Avatar
TJZ
Sorry you think that only Turbos will give you power the higher RPMs. You obviously don't know much about forced induction since you were saying how we needed power in the higher RPMs, then started to bash superchargers with your small illustration. Maybe I should list some dyno sheets were a certain turboed car and supercharged car has the same peak horsepower.[/img]
Easy there cowboy. I know a good bit about FI and I don't appreciate you putting words in my mouth. I was discussing turbos and power curves with another member and you say "SCs also give power up top". Um....ok...congratuations for going completely off topic. I know this buddy, so please don't pretend to make yourself feel like a bigger person by attempting to belittle me. The fact remains, we weren't discussing SCs, and then you come a long trying to start a flame. Not only is this childish and annoying, it is also against forum rules.
If my smilie in my first post offended you, I apologize.
Old Dec 27, 2002 | 11:55 AM
integrate's Avatar
integrate
Sorry, I was only trying to add to the fact that a supercharger would be fine in the matter of adding power up top. How is talking about a supercharger off topic? If we're talking about forced induction in general, then we should look at the whole horizon before making assumptions. You gave me the impression that you didn't know what you were talking about by bashing superchargers and saying only a turbo will give power in the higher RPMs. It was very obvious you were doing that. Now, if you can't comprehend that, then sorry.
I apologize if I was belittling you. Your posts gave me the idea that you had no idea what you were talking about. Instead of backing up your statements, you just replied with your "off-topic" nonsense. My posts at least show technical reasons as to why the SC will do fine, but your posts just tell me that I can't read.
YOU made the illustration of the smiley face shooting the supercharger. If we weren't talking about SCs, why did you feel the need to add the illustration?
I'm sure you know a lot about forced induction.
Cheers
If you want to keep this going, PM me instead.
Old Dec 28, 2002 | 12:21 AM
Cintel7's Avatar
Cintel7
Speaking of ECU.. remember the AFC ( Air Fuel Controller)..
if we can install that SUCCESFULLY, wonder how that would affect the performance.
Old Dec 29, 2002 | 11:22 AM
articfury's Avatar
articfury
Charter Member #55
integrate-
Read the Subject of this thread. It says Turbos, not FI in general. This is why TJZ is saying that your numerous posts about SC are off topic. If you want to discuss all FI options and Linearity, then start a thread on it.
Back on topic-
The linearity of turbo acceleration is directly related to the sizing and design of the turbo and overall setup. Proper sizing and setup can produce minimal, if even noticably different, "lag" and a sizable power gain. That said, if you want extreme horsepower numbers, lag is most likely unavoidable.
JD
ti837
Sep 22, 2015 07:46 AM
