View Poll Results: CAMS
Jim Wolf
30
34.48%
Nismo
25
28.74%
Tomei
32
36.78%
Voters: 87. You may not vote on this poll
Cams
Old Oct 25, 2005 | 09:00 AM
rednezz's Avatar
rednezz
Originally Posted by Machupo
i'm running a stock tune with a raised idle (along with the technosquare F-spec flash)... the top hp was only about 245 (i have the dyno sheet in the car, which is at the body shop) -- mainly because i have a lower compression ratio, stock plenum/headers, no tune (oh, and the engine was brand new )... that's all in prep for the TT system that will go on shortly, then a retune to a nice level
as for the power curve with the tomei's it's pretty awesome (running rather lean at the top end though, so i'm looking forward to a tune!) -- hopefully i'll get the car back and get the intake straightened out down at crawford... i'll see if i can re-dyno it at the same time and get back to you!
Thanks I appreciate the info.
Old Oct 25, 2005 | 10:53 AM
Nismo 350z's Avatar
Nismo 350z
Do any cams pass emmissions?
Old Oct 25, 2005 | 11:00 AM
sentry65's Avatar
sentry65
the burninator
could be wrong, but I don't see how they'd be a huge problem with emissions
Old Oct 25, 2005 | 11:27 AM
iRRATiONAL's Avatar
iRRATiONAL
Originally Posted by Nano
I thought JWT cams = Nismo cams
that was my impression also
Old Oct 25, 2005 | 12:33 PM
sentry65's Avatar
sentry65
the burninator
JWT are not nismo cams
they're similar
JWT cams have more power up top and less down low, but still similar
Old Oct 25, 2005 | 01:29 PM
zzzya's Avatar
zzzya
Rumor has it that Jim Wolf makes the Nismo cams, but the Nismo cams on the market are not the same grind as the marketed JWT S1 cams. Different intake and exhaust profiles as well as a more aggressive lift on the JWT cam.
Old Oct 25, 2005 | 01:46 PM
Machupo's Avatar
Machupo
I think Jim Wolf was the shooter on the grassy knoll!
Old Oct 25, 2005 | 01:55 PM
azzaz's Avatar
azzaz
do you have to change your valve springs when adding an aggressive cam such as the tomeis,
do they come with everything needed for installation ie: gaskets
Old Oct 25, 2005 | 02:41 PM
sentry65's Avatar
sentry65
the burninator
i'm pretty sure the tomei 268's are a lot more work than nismo or JWT
Old Oct 25, 2005 | 03:14 PM
Machupo's Avatar
Machupo
yup, put high-lift springs (nismos, incidentally... they're the same as the tomeis) and the engine mechanic did the rest of the fitting /machining work.
Old Oct 26, 2005 | 01:03 AM
GAaaAR's Avatar
GAaaAR
Is there a difference between the R-Tune Nismo Cams and the regular Nismo Cams?? If there is wouldn't the R-Tune Nismo cams be better than the tomei's???? I kno the r-tune cams are illegal in the streets, but how would anybody kno?? LoL
Old Oct 26, 2005 | 01:32 AM
mchapman's Avatar
mchapman
Japanese NISMO Spec2 are the only option if your going all motor, these plus VTC pulleys to retain low end torque. Spec1 also give good gains but if your going all out then there is no reason to get the Spec1s, so Spec2 it is (284 intake duration 11mm lift/268 exhaust 10.5mm lift).
No other cams come close to these, Nismo R-Tune are milder than JWT and Tomei 268.
You will also need upgraded valve springs and an engine management which can use everything. UTEC will be able to at some point but Motec can now.
Old Oct 26, 2005 | 07:34 AM
1fastz4sure's Avatar
1fastz4sure
so for all around power low end and top end is there a choice?
sounds like jwt is top end...
nismo all around right? or was tomei all around?
i was contimplating this as well.. i was looking at tomeis 264's
let me know too
Old Oct 26, 2005 | 09:02 AM
350ZLO's Avatar
350ZLO
now that ive hearda ll of this i think im gonna change formthe tomei's to the nismo spec 2's. i have to drive the car everyday i dont want a car thats only powerful up top so i think im gonna go with the most balanced cans which from this thread sounds like the nismo spec 2's......am i understanding this correctly
Old Oct 26, 2005 | 10:06 AM
Nismo 350z's Avatar
Nismo 350z
Are the Japanese Spec 2 the same as the Nismo S1 cams available here??
Old Oct 26, 2005 | 02:16 PM
azzaz's Avatar
azzaz
do you need a complete engine management system to run the tomeis or will a piggy back work fine like a uni chip. or even the stock computer
Old Oct 26, 2005 | 02:23 PM
Machupo's Avatar
Machupo
i've got the stock ECU with the technosquare F-spec reflash, but no fuel/timing edits... am waiting till the TT system goes on with the EU and return fuel system to do the tuning
Old Oct 26, 2005 | 04:12 PM
  #38
mchapman's Avatar
mchapman
No.The Nismo cams sold in the states are milder than JWT, Tomei 264, 268, Nismo Spec1 and Spec2 cams.
The US Nismo cams are 262 duration. The Japanese NISMO Spec 2s are 284 intake duration 11mm lift/268 exhaust 10.5mm lift. They are much bigger.
For reference the Tomei 268 cams are 268 intake duration 10.5mm lift and 268 exhaust 10.5mm lift.
Old Oct 26, 2005 | 04:31 PM
  #39
mchapman's Avatar
mchapman
The Spec 2s are the biggest cam available for the 350z. By themselves they will be anything but what you want. But they can be used while still retaining low end torque IF you use them with the Nismo VTC pulleys and appropriate engine manegement which has the ability to control the VTC pulleys and have it tuned accordingly.
Old Oct 26, 2005 | 04:32 PM
  #40
sentry65's Avatar
sentry65
the burninator
yeah the nismo spec 2 cams are not what you want
really any of the other cams will be fine for you, just not those
