KJR pulleye owners... what is you opnion on them... how do they preform
Old Oct 24, 2005 | 10:11 PM
zmespeed's Avatar
zmespeed
Exclamation KJR pulleye owners... what is you opnion on them... how do they preform
i have the pulleye but the bolt on the stock one is a ***** to get off. tried every trick in the book, is it worth all the effort that i must go threw to get it on. does it make a little differecne or a noticable differance.. in revs power..l.other. thanks in advance
Old Oct 25, 2005 | 05:21 AM
MrKaira's Avatar
MrKaira
Really MrZ31
it is a ***** to get off, i tried to do it myself (without using the method of putting the bar on the ground and turning over the motor letting it do it itself) so i had a buddy of mine that has a shop do it, he did it that way and it came right off, so i felt pretty dumb. That was before summer, and I am pretty sure that I noticed a nice gain from it initially. No dyno around here, not yet anyway. I was definately glad I didnt have to deal with different belts or underdrive... those were the two main reasons I got the KJR... but i would recommend it
Old Nov 11, 2005 | 02:25 PM
sisco534's Avatar
sisco534
I got the UR crank pulley , OEM is a biatch to get off...I tried then took to shop charged me 85.00 but that included 2 new belts(UR SAYS NO BELT CHANGE BUT THEY ARE WRONG).....It is all about the wieght UR weighs 1.6 pounds and stock weighs 6.4 pounds. I can spin tires in 1st gear with ease(used to have to pop clutch). I think if you are going FI KJR is the choice but you may get a little better gain from UR but hell they are all the same but the weight is where it helps, it revs faster too.Best mod I had so far.Time to dyno again before the Pulley 248.9 whp I need more power it gets adictive as drugs. Easy DIY if you can get the damn OEM off.
Old Nov 11, 2005 | 03:34 PM
Pats300zx's Avatar
Pats300zx
ECZA-President
I just had the UR pulley installed today and I love it. I can tell an increase in power. The OEM pulley was a ***** to get off. I had a shop do it and they had to use a chain wrench to get the old pulley off.
So far so good. No belt squeaking etc. I am very happy with the mod.
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
