Flywheel/Crank pulley ?
Old Nov 30, 2005 | 01:43 PM
03_Track_Z's Avatar
03_Track_Z
Default Flywheel/Crank pulley ?
I used to own an M3 and with those cars I know you cant do both of these mods, what about on the Z? Will the balance get thrown off? I eventually want to get a sueprcharger so I was looking into the KJR factory-size crank pulley. And I'm also looking at the JWT Clutch/Flywheel combo. On that note, will the JWT clutch be enough to compensate for the vortech's added power? Thanks.
Old Nov 30, 2005 | 05:29 PM
100122923's Avatar
100122923
Yea, I want to know this too. My installer warn me about the flywheel + pully combo. he said it's better to get the crank balanced, if not the crank bearing will go eventually.
Old Nov 30, 2005 | 08:45 PM
Z BOY's Avatar
Z BOY
these questions have been answered like a million times already. why don't you take the time to "search"???
Old Nov 30, 2005 | 09:32 PM
03_Track_Z's Avatar
03_Track_Z
in the time it took you to write all that you could have easily typed "yes" or "no"
Old Nov 30, 2005 | 11:51 PM
bleunetizen's Avatar
bleunetizen
exactly
Old Dec 1, 2005 | 01:17 AM
taurran's Avatar
taurran
There are people on this forum with both. They work fine as far as I have heard.
Yes, the JWT setup would be perfect for the Vortech on the stock motor.
Old Dec 1, 2005 | 05:01 AM
Mike Wazowski's Avatar
Mike Wazowski
I am running both no problems. I am also running the JWT clutch which is handling my built motor and JWT TT set up without any problems so there should be no issue with teh Vortech
Old Dec 1, 2005 | 07:26 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You can run both fine, they are both balanced before getting to you! As long as you dont get a piece that somehow passed a QC when it shouldnt have you'll be fine-chances of that happening are very low. M3's are I-6's their cranks are waayyyy long, I would assume people dont/shouldnt run crank pulleys with no dampners on them because of the size of the crank and the resonance they produce, especially with an 8000 rpm redline. Z' has a low redline and is a V-6, your comparing apples to oranges. FWIW Ive had my CP for 30+ miles some o fwhich have been with a 7100 rpm redline no issues.
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
