differential leak
Old Dec 2, 2005 | 09:12 AM
dirtroad's Avatar
dirtroad
Default differential leak
So I noticed that my diff was leaking, so I took out the top plug and gear oil spurts out, probably half a quart or so. Looks like the place that put in my LSD overfilled it since it should only be filled to the level of that upper plug. I'm wondering if this could have caused any damage, other than breaking the seal somewhere? I'll most likely open the whole thing up and reseal it - what is used to seal up the pumpkin, or is it just a gasket or something?
Old Dec 2, 2005 | 09:57 AM
aaronlosey's Avatar
aaronlosey
you can use rtv sealant from the auto parts store. i've done dozens of them that way.
Old Dec 2, 2005 | 10:33 AM
overZealous1's Avatar
overZealous1
kinda curious how they even got it filled that much.
Old Dec 2, 2005 | 11:17 AM
mavtais's Avatar
mavtais
somebody at the repair you took your car to has really quick hands!
Old Dec 2, 2005 | 06:38 PM
dkmura's Avatar
dkmura
General & DIY Moderator
It's possible to overfill a diff by having a car not leveled out properly on the lift. If the nose is slightly down, the level at the diff fill hole changes and you can overfill it. That also applies the opposite way in checking the diff- was your car absoutely level when you pulled the plug?
In my experience, a slight overfill shouldn't hurt anything. If you had a specialized LSD installed, you may want to check the installation instructions to be sure that it doesn't call for additional gear oil.
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
