need help with installation
Old Dec 26, 2005 | 10:47 AM
hendo6682's Avatar
hendo6682
Default need help with installation
hey, i got a few new parts for my car this year for christmas. 2 of them didn't come with instructions (i think they were from ebay) and i was just wondering if anybody could help me out. i got a rogue short shifter and an unorthadox crank pulley. i'm not sure i want to try and start these installs without some sort of instructions. i have searched on the web but came up empty. any input would be appreciated. thanks
Old Dec 26, 2005 | 09:57 PM
overZealous1's Avatar
overZealous1
if you need instructions for those parts, it is prolly better left to a pro.
Old Dec 27, 2005 | 04:01 PM
gersteinp's Avatar
gersteinp
http://www.rogueengineering.com/pdf/...er_install.pdf
Screw the pros.
Old Dec 28, 2005 | 05:03 AM
Midnyte's Avatar
Midnyte
for the crank pulley you need to loosen the bolts on both of the tension pullies, then use the adjustment bolts on them to releive the tension. Pull the belts off, and use your breaker bar, or the starter/crank method mentioned elsewhere in this forum to loosen the bolt on the crank pulley. Wiggle pulley out. Reverse for installation.
Here is a thread on trying to get the pulley off...
https://my350z.com/forum/showthread....pulley+install
It wasnt that bad (unless you had to remove your turbo piping like me). You'll love it when its done. If its a lightweight pulley your stock belts will work. If its an underdrive pulley, you will need different belts...not sure on the size.
Old Jan 2, 2006 | 07:39 AM
hendo6682's Avatar
hendo6682
thanks for the info fellas, and by the way, i don't think i need a pro to install a damn pulley and short throw shifter, just wanted something to look at to make sure i wasn't forgetting anything.
Old Jan 2, 2006 | 10:09 AM
overZealous1
wasn't trying to underestimate your abilities, but i have seen people do some really stupid things, lol. good luck.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
